Help with mounting the octopus to the carbs
  • OldGreyBeast
    • Mar 2024
    • 100
    • Florence, AL, USA
    Does anyone have any pictures of how the Octopus is mounted to the carbs? I've tried scouring ebay and whatnot but all the pictures are obscured by the hoses or just at bad angles. I know it goes on top of the carbs somehow but the screw holes don't seem to line up.
  • jkorn
    • May 2003
    • 188
    • Wickenburg AZ
    Octopus. What’s that? My 79 does not have one.
    Jeff Korn
    Original Owner 79XS1100 E
    • OldGreyBeast
      • Mar 2024
      • 100
      • Florence, AL, USA
      It's unique to the special edition I believe. Some sort of vacuum fuel shutoff thingy or some such. I know a lot of people delete them but I'd like to set this bike up as it was originally intended.
      This is a 1979 Special btw.
        • 7818
        Let me try this. It's a MNS carb set, stock, with the octy in the stock location. Click image for larger version  Name:	Carb2r.JPG Views:	0 Size:	142.1 KB ID:	880341 Click image for larger version  Name:	Carb3r.JPG Views:	0 Size:	131.3 KB ID:	880342Note that the MNS has the mount bracket for the octy! The Specials have one of the three brackets for the carbs that does have the mount position on it.
        • OldGreyBeast
          • Mar 2024
          • 100
          • Florence, AL, USA
          PERFECT! Thanks so much! I actually have one of those curved brackets in a random parts batch I got off eBay! Didn't even think about using that.
          • jkorn
            • May 2003
            • 188
            • Wickenburg AZ
            On the standard 1100s there is a vacuum shut off on each side of the fuel tank which only allows fuel when there’s vacuum so there’s an on prime and reserve position.
            Jeff Korn
              • 2011
              You will need this bracket as shown in Rays picture.
              https://www.ebay.com/itm/27646429388...Condition=3000
                • 2011
                • OldGreyBeast
                  • Mar 2024
                  • 100
                  • Florence, AL, USA
                  Ah yeah the bracket I had was just another throttle cable holder. Thanks for the eBay link, I ordered that bracket, all I have left to do with the carbs now is weld on a choke lever, then they can go back on the bike!
                    • 2011
                    Not sure if this will fit your carbs.
                    https://www.ebay.com/itm/32475922227...Bk9SR_ryjMOIZA
                    • OldGreyBeast
                      • Mar 2024
                      • 100
                      • Florence, AL, USA
                      It looks the same, but I can weld up my broken one for free :P
                        • 2011
                        Free is good.
                          • 7818
                          Like me? "I have a TIG welder and I'm not afraid to use it!"
