Sofa
    • 1975
    Mike, I would say the tach would be the most sensitive device to noise/ bad ground on the bike and would be the first to show an issue. It's a possibility. I guess it could still be in the stator. Maybe also try a spare main voltage regulator for "clean" power. Maybe one of the diodes in the bridge is acting odd and not quite rectifying.
      • 2120
      Tach is counting unrectified pulses.
        • 7795
        You DO NEED good grounds for everything to work properly. Electrical problems on older bikes are almost always a ground issue. Go through, clean every ground wire and screw on the bike and see if that helps.
          • 1975
          Yes, but in order for it to do so it must also have power and ground. Clean power and ground.
            • 2120
            Yeah, I had thought that as well. I'm imagining the battery adds stability.
              • 1975
              It absolutely adds stability. Positive and negative are the reference points of the signal wave. If they are off or unstable (changing) the coordinates will be off.
