hello everyone, well I got my carbs cleaned and new shims the bike runs great but my blinkers stopped working. they don't light up at all. the fuse is good. it was real tight getting the valve cover off to put the shims in, i had to take the fairing and all the braces off so i thought i might have pulled a wire apart around the head light or around the coils but i can't find the problem. thanks
no blinkers on my 1979 xs1100f
The brown wire is the hot wire, the brown/white runs to the switch. With the key on, put the switch in either the left or right position. With the flasher removed, jump the brn and brn/wht wires at the plug. The left or right signals should light up but not flash. If they light up, your problem is the flasher, if they don't light up, the problem lies elsewhere in the wiring or the switch.2H7 (79) owned since '89
Originally posted by bikerphil View PostThe brown wire is the hot wire, the brown/white runs to the switch. With the key on, put the switch in either the left or right position. With the flasher removed, jump the brn and brn/wht wires at the plug. The left or right signals should light up but not flash. If they light up, your problem is the flasher, if they don't light up, the problem lies elsewhere in the wiring or the switch.
Originally posted by roger View Post
jumped the wires nothing lit up.1980 XS1100G
I identify as a man but according to the label on a package of Stauffers Baked Lasagne I'm actually a family of four!
Originally posted by LAB3 View Post
Whenever I pull my fairing off there's a nest of wires that used to be housed in the headlight bucket that are now kept inside some sort of vinyl bag. It's not difficult to jostle that bag around while removing and reinstalling the fairing, I'd be looking there for a disconnected pair of wires.
howdy Roger,,,,same thing happened to me,,,,I had a broken brown wire at the connection coming from the left handlebar switch at the plug which is under the gas tank,,,,lift the tank up and there is two connections,,,try a 12 volt test light on the brown wire and brown with stripe wire with the key on for power,,,,also these bikes usually have to be running to get enough juice to get the signal flasher to work,,,many have replaced with a electronic flasher which requires way less load and works better...keep us informed,,,,a test light will be your friend along with a electronic flasher................Mike in San Diego and Pa.
Originally posted by Socer4m View Posthowdy Roger,,,,same thing happened to me,,,,I had a broken brown wire at the connection coming from the left handlebar switch at the plug which is under the gas tank,,,,lift the tank up and there is two connections,,,try a 12 volt test light on the brown wire and brown with stripe wire with the key on for power,,,,also these bikes usually have to be running to get enough juice to get the signal flasher to work,,,many have replaced with a electronic flasher which requires way less load and works better...keep us informed,,,,a test light will be your friend along with a electronic flasher................Mike in San Diego and Pa.
I read that blue is for your running lights so i plugged one of the female hot wires to a blue male wire that goes to the pigtail of the fairing and with the switch on ive got running lights on the front.I have one gray male wire and one red one none are hot. I have two more blue female wires and one is hot and one is not. ive tried plugging them different ways but nothing works.
Do you have a good ground for the fairing? If the current can't return to the battery, no current. I put a "new" ground wire on all the fairings I've used. Goes from the fairing ground wire direct to a bolt on the front of the frame.Ray Matteis
Some where in here is a thread on “fixing” the blinker can thing. I had to do it to mine years ago, but yours sounds like a loose wire somewhere.
where did you get that replacement fuse block. Mines failing. Little ears breaking off the hold the fuses. JeffJeff Korn
Original Owner 79XS1100 E
Originally posted by DiverRay View PostDo you have a good ground for the fairing? If the current can't return to the battery, no current. I put a "new" ground wire on all the fairings I've used. Goes from the fairing ground wire direct to a bolt on the front of the frame.
Originally posted by jkorn View PostSome where in here is a thread on “fixing” the blinker can thing. I had to do it to mine years ago, but yours sounds like a loose wire somewhere.
