Beginning an XS1100SF restoration - first of many questions I'm sure
    • 1798
    Found one in a pile of old hardware.
    FOR SALE: misc bolts. ORIGIN: 1978 Yamaha XS1100with 12,587 miles. Any major flaws in any parts are DISCLOSED to YOU, to the best of our ability. All issues can be worked out.
Name:	kicker clamp.jpg
    I have purchased several of these type Ebay listings just for one piece or the other over the years.
    • dpotter58
      • Aug 2004
      • 1833
      • Southern Maryland
      pretty sure there is a RLU here and probably those nuts. PM me your address and I'll mail them to you
      1980 LG
      1981 LH
      • OldGreyBeast
        • Mar 2024
        • 92
        • Florence, AL, USA
        Thanks for all the help guys The bike is coming along nicely. I got an XS650 tail light adapted to the 1980 harness with the parts from Yambits. Got the rear blinkers from eBay and installed those, and the grab bar. CAD'd up and 3d printed the rubber dampers that go on the headlight housing/fork ears to get the front sorted out. I'll have pictures of that later and will post the STL files for the stuff I've drawn up for printing in another thread once I verify it all works. I also designed and printed a replacement battery tray, going to work on a battery hold down next.
          • 1422
          Nice clean workshop.
            • 1798
            His workshop is the reason I am single.
              • 1422
              • OldGreyBeast
                • Mar 2024
                • 92
                • Florence, AL, USA
                #37
                I got lucky and found a wife that's as into bikes as me XD Took 37 years though...
                • Rasputin
                  • 3180
                  • Lacombe, Alberta, Canada
                  #38
                  get your own parts fiche and manuals as they are invaluable, They are here on the site. https://xs11.club/forum/maintenance/...ch-in-jpg-form
                  2-79 XS1100 SF
                  2-78 XS1100 E Best bike Ever
                    • 1422
                    Also:
                    • OldGreyBeast
                      • Mar 2024
                      • 92
                      • Florence, AL, USA
                      #40
                      I've very nearly got this wiring harness all sorted out. There's a few wires that even with the wiring diagrams I can't figure out.
                      First, is there supposed to be something screwed down to the terminals on the "Main fuse block" here?
                      Second, what gets plugged into this red wire? Note this is a 1980 XS1100 wiring harness. It's close to regulator/rectifier and the reserve lighting device.
                      Third, what's this dark green wire that's connected to the same wire as the starter supposed to connect to?
                        • 7608
                        #1. That is the "accessory fuse" and there is nothing connected to it from the factory. That is 10Amps for a radio, etc.
                        #2. Not sure what that is, as all my bikes are older. It does NOT look like a factory connector, though.
                        #3. That is for the "older bikes" that have the ballast resistor. It will give full voltage to the coils when starting the bike. Not used in the later models with the larger Ohm coils.
                        • OldGreyBeast
                          • Mar 2024
                          • 92
                          • Florence, AL, USA
                          #42
                          Thanks a ton!
                          My bike is a '79, would it have a ballast resistor?
                            • 1798
                            Originally posted by OldGreyBeast
                            Thanks a ton!
                            Yamaha Motorcycle 1979 OEM Parts Diagram for IGNITION COIL - BATTERY - HORN - WIRE HARNESS | Partzilla.com Look at item 50. That is the ballast resistor. I think that green wire by the solenoid goes to the rear turn signal. There should be a brown one just like it on the other side. Do you have oem original coils on the bike or replacement? Are the coils 1.5 or 3 ohms? If 3 then they have been replaced and you won't need the ballast resistor and the two wires that would go to it simply need to be plugged in to each other to bypass it. I am not sure about that red wire.
                            • OldGreyBeast
                              • Mar 2024
                              • 92
                              • Florence, AL, USA
                              #44
                              Ok so mine does have the ballast resistor and it's connected up where it's supposed to be. The turn signals are connected up. This green wire is part of the wire that feeds power to the starter. It's weird. Maybe it's just for an accessory or something? It's got a female bullet connector.
                              The odd red wire also has a female bullet connector.
                              • OldGreyBeast
                                • Mar 2024
                                • 92
                                • Florence, AL, USA
                                #45
                                Finally figured out what the red wire is, it's supposed to be pinned into the connector that the reg/rect connects to. I'm not sure why someone disconnected it. I reckon I'll cut the reg/rect connector off my old harness and solder it in in place of the cut one.
