This is interesting....
  • Lord Grizzlon
    • Mar 2003
    • 101
    • Bklyn, NY
    I was workin on Exodia today and had an interesting problem. idle is ok..crack throttle alittle...ok drops bak to norm. hit 2.5k-3k and then it will keep climbing. i cleaned carbs, lubed slides w/ wd40, checked throttle cabel and she still will climb. went 4 a ride like this.. interesting to not hve to use clutch as much, but dangerous. help!
    L. G.
    1979 XS1100SF
    Exodia, "The Forbidden One"
    1988 CBR600F Hurricane
    Tempest- died Aug. 10, 2005
    198x XS850
    -no name yet-
  • bandet01
    • 698
    • connersville indiana
    i had the same problem and it was the return spring had feel off and it stuck at wide open and my throttle idle adjuster had backed all the way out and got caught in between the shaft
    79 yamaha xs1100f standard
    best 1/4 mile 13.282@99.40
    • 81xsproject
      • 3185
      • Fortuna, CA
      I had something similar from flooding
      '81 XS1100 SH
      Sep. 12th 2015
      RIP
      • red bandit
        • 956
        • central michigan
        first make sure your springs and cable are all correct. not broken, hanging up or whatever. if your SURE the butterflies are closing properly. clean the carbs. i've had more than 1 carb do this.
        79 SF parts bike.
        • Geezer
          • May 2003
          • 2985
          • Willamina, Oregon 97229
          It might be an air leak. Pull the carbs and intake boots. Then reseal the boots with Yamabond #5 where they meet the cylinder head. Put it all back together and se how she runs.
          Geezer.
          • Lord Grizzlon
            • Mar 2003
            • 101
            • Bklyn, NY
            i had used copper head gasket sealant the last time... could this be a/ the prob?
            L. G.
            1979 XS1100SF
            198x XS850
            -no name yet-
            • Geezer
              • May 2003
              • 2985
              If you used silicone slealer probably otherwise it depends on how long ago you did it.
              While you have it apart, hang the cable with a bag of oil on one end to lube it. It never hurts and is much better than spray lubes.
              Geezer
