I was workin on Exodia today and had an interesting problem. idle is ok..crack throttle alittle...ok drops bak to norm. hit 2.5k-3k and then it will keep climbing. i cleaned carbs, lubed slides w/ wd40, checked throttle cabel and she still will climb. went 4 a ride like this.. interesting to not hve to use clutch as much, but dangerous. help!
This is interesting....
L. G.
1979 XS1100SF
Exodia, "The Forbidden One"
1988 CBR600F Hurricane
Tempest- died Aug. 10, 2005
198x XS850
-no name yet-Tags: None -
i had the same problem and it was the return spring had feel off and it stuck at wide open and my throttle idle adjuster had backed all the way out and got caught in between the shaft79 yamaha xs1100f standard
best 1/4 mile 13.282@99.40 -
I had something similar from flooding'81 XS1100 SH
Sep. 12th 2015
RIPComment
first make sure your springs and cable are all correct. not broken, hanging up or whatever. if your SURE the butterflies are closing properly. clean the carbs. i've had more than 1 carb do this.79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box, 750 FD.
79 SF parts bike.Comment
It might be an air leak. Pull the carbs and intake boots. Then reseal the boots with Yamabond #5 where they meet the cylinder head. Put it all back together and se how she runs.
Geezer.Hi my name is Tony and I'm a bikeoholic.
The old gray biker ain't what he used to be.Comment
i had used copper head gasket sealant the last time... could this be a/ the prob?L. G.
1979 XS1100SF
198x XS850
-no name yet-Comment
If you used silicone slealer probably otherwise it depends on how long ago you did it.
While you have it apart, hang the cable with a bag of oil on one end to lube it. It never hurts and is much better than spray lubes.
GeezerHi my name is Tony and I'm a bikeoholic.
