Mirrors Issue
  • HugoF
    • Nov 2023
    • 1
    • France
    Mirrors Issue
    Hello.
    I'm grateful for the existence of live sex cams and the endless possibilities it offers in terms of sexual exploration.
    • 7640
    A lot of aftermarket mirror companies DO make the mirrors for the Yamaha with left/right hand threads. I know I use aftermarket mirrors on my XS, and others have as well. I'm not sure who you can go through in the EU, but a few of the online shops in the US list the mirrors. You need to look at the "stalk" length, or how long the metal bar is from the bolt to the mirror head.
      • 717
      Another option may be to use these righthand to lefthand thread convertors.
        • 8671
        One time when I had narrow handlebars on my bike, I used two pieces of 1/8" thick 1" flat bar steel about 2 1/2" long, drilled a 10mm hole near each end, bolted them to the bike mounts, then bolted the mirror to the flat bar. I will try to find a picture. Here it is...
          • 7781
          XS1100 Special handlebars will fix it. It will get the mirrors right on out there.
            • 7781
            I’m sorry. I know that’s not helpful. Post a picture of your bike, so we can see what you’re working with.
              • 1484
              I know that guy.
ID:	875899 Click image for larger version
                • 1484
                On a more constructive note, I drill out the left hand mirror mount and Helicoil a 10mm right hand thread in it so it is conventional. Mirrors need to be convex so you can see around you.
ID:	875902 Click image for larger version
                  • 5051
                  .Awe, tell the truth, you took a picture of your wheelbarrow's handlebars!
                    • 7781
                    I certainly could have. I’m rocking those bars on my Special. My XS650 as well. My mirrors work fine without a view of my elbows.
                    • Mathh
                      • Nov 2006
                      • 667
                      • Beek, Netherlands
                      I use a universal bar end mirror on my XS's (left side). They are available in several sizes and with different mirrors. They can be folded out of harm's way when manoeuvring. My girlfriend uses two (left and right).
                      MV Agusta Brutale 910R '06.
                      Yamaha MT-09 Tracer '15 grey.
