Rewiring for M.Unit Blue, TCI Wiring & Turn Signals
  • 10Mdg
    • Aug 2023
    • 2
    • Florida/NYC
    Hey everyone! Happy to be here on the forum.
    I'm rewiring a new harness for my 80' XS1100 SH (based on the 4R0 VIN, I believe its an early 81' SH). The bike was previously owned as a partially built cafe racer project that I've been finishing.
    The original wiring harness was heavily modified by the prior owner and suffered a lot of leaks/drains - the battery would drain after a day. I've rewired nearly all of the wiring harness but can't figure out how to get a spark from the TCI with the wiring diagrams I've found online, in conjunction with the M.Unit Blue. The starter runs fine when giving run a push, but she's not igniting afterwards. Looking at wiring diagrams there's a red and black wire I can't figure, as well as several wires previously missing from the connector. Additionally, I can't for the life of me figure the wiring for the three-way turn signal switch and high/low lights to run to the M.Unit from an M.Button system, in Config C. I can get both R/L to fire at the same time... but not separately.
    Any advice would be appreciated.
    • 2004
    I found this digging around the forum.
      • 2004
      From the manual.
        • 812
        Wouldn't it be nice if that's all a TCI is made of is two transistors and a diode?
          • 2004
          LAB3. soon I'm going to disassemble a TCI to see what is exactly inside including parts and part numbers if possible. Here is a better schematic with wire colors and polarity explanations.
          • Mathh
            • Nov 2006
            • 696
            • Beek, Netherlands
            I have a pdf from someone who made a replacement board for a TID14-04 for a 1981 XS1100 Sport (EU model). Maybe that can help you. Can't get it online though. Maybe if you sent me a pm with your emailadress?
            MV Agusta Brutale 910R '06.
            Yamaha MT-09 Tracer '15 grey.
              • 2004
              I think this is it
              • Mathh
                • Nov 2006
                • 696
                • Beek, Netherlands
                This is from Werner in Germany. He does however mention Henk's work under TD14-07 ..
                • Mathh
                  • Nov 2006
                  • 696
                  • Beek, Netherlands
                  Here is a link to Henk Waaijer's work, it is in Dutch however. But you can do your own downloads from everything he did.
                  https://www.motor-forum.nl/threads/y...d14-04.455639/
