'78 XS1100E, '80 carbs low rpm funk
  • gtem
    • May 2023
    • 235
    • Indianapolis
    #46
    All,
    An update on the '78E with '80 carbs situation: I think I've almost got it. So the current setup is the gentler 5IZ7 needles with 120 mains, I went down to #40 pilots, and am finally getting a decent color on the plugs, pending more testing. The last remaining issue was cyl #4 kept getting a sooty plug. I checked and rechecked everything, tested the choke circuit for leakage, etc. The rest of the carbs had the idle mixture screws set out to 3 turns out with the #40 pilots but #4 would get sooty even with just .75 turns out. Finally I pulled the mixture screws from cylinders 3 and 4 to compare, and did some flow testing with WD40 through the idle circuits and saw that #4 was flowing more past the idle mixture screw even though it was turned in tighter! Upon disassembly of #3 and #4 idle mixture screws I found that the o-rings are all pretty compressed into a tapered conical shape (the seat that they are pressed against). Well it seems that at some point when messing around I had reversed the direction of the o-ring on #4, and somehow(?) that was causing problems. Or maybe my "flow testing" fixed something. I don't know. But I swapped the idle mixture screws on 3 and 4 and the rich condition on #4 seems to have been resolved. The bike has the cleanest idle it's ever had, I've never been able to lug it down to 2000rpm like this before. I'll be fine tuning the idle mixture screws a bit more, I think I'm a tad lean at the moment (set them to 2.5 turns out). I'm also considering repacking the RC pipe with some looser type fiberglass wrap to help it flow a bit better (hopefully without getting too loud).
    '98 GSF1200S '81 GS850G
    • gtem
      • May 2023
      • 235
      • Indianapolis
      #47
      A further update on the '78E with '80 carbs and RC 4-1 pipe (#40 pilots, #117 mains, 5IZ7 needles),:
      I had started to get sooty plugs again, I had about lost my mind! Well I finally thought to take a peek, and realized the crusty old baffle had collapsed inside of the exhaust, restricting flow quite a bit. Re-welded the baffle and repacked it, I'm now back to clean plugs. The baffle in the pipe has roughly a 1-3/4 to 2" ID, perforated metal surrounded with fiberglass packing. When the bike is warmed up it will do some light juddering from a 3000rpm roll-on but then cleans up and pulls nice and hard to 90+mph Some backfiring when coasting down in gear, that seems to go away when I put choke to the halfway on position. It doesn't like to sit and warm up on choke, I almost immediately take it fully off and just bounce the throttle lightly until it holds and idle about 30 seconds-1 minute after starting the bike.
      So it seems like I'm back to some low-speed/transition circuit tuning. A check with my colortune shows a nice blue at idle and it mostly maintains that when revved, there is a moment where it looks a bit orange, but it's hard to simulate accelerating against a load when just doing static revving. Below are photos of plugs #4 and #1 with the idle mixture screws turned out 3 turns with the #40 pilots.
      Does the sooty base ring imply a rich idle/low speed mixture? I'm not experienced enough yet to have that dialed in feel to tell a lean stutter or backfire from a rich one. Bike doesn't smell too gassy or anything at idle, idle feels very nice and smooth. Before, the plugs would be totally sooty including the entirety of the ground strap. They're staying remarkably clean now.
ID:	878760 Click image for larger version
      • gtem
        • May 2023
        • 235
        • Indianapolis
        #48
        A further update on this:
        I took the '80 Special carbs back to their stock jetting and needle arrangement. I had mentioned a rough sort of warm up procedure, that ended up being one clogged up choke fuel pickup passage in the bowl of one cylinder. The #40 pilots were just too small, I went back up to 42.5, although once again, I only have .75 turns out from seated on the idle mixture screws (with new o-rings). The low end response is... good enough. The bigger issue had turned out to be some breaking up at high load (full throttle, from 4000rpm on up). I was convinced my change to 115 mains was to blame, so I swapped back to a stock (for a a 1980 Special carb) #110. Still the same issue.
        At this point I realized, I may very well be dealing with an *IGNITION* issue. It feels *exactly* like when I had a broken pickup coil wire.
        So I started by checking over the pickup coil wires, I had repaired one previously. No obvious issues. I traced that cloth-loomed harness all the way back to the connector behind the fuse panel, again, nothing obvious. I then started to inspect around the coils (PO had swapped them to Dyna 1.5ohm "orange" units at some point, keeping the stock ballast resistor). One thing I tested was said ballast resistor, and I got a resistance value of 3.4ohms, a good bit more than the expected 1.6. Could this be my problem? I'm going to test the coils themselves this evening and inspect the wires closely. I had recently replaced the plugs with brand new NGK BPR6ES (running non-resistor wires). I will inspect the plugs as well.
          • 813
          #49
          Don't know how many times I've seen "carb problems" turn out to be ignition problems! Can I say it's the fault of the ballast resistor? No but one thing is for sure, if it's that far out of spec then replacement is in order.
          • gtem
            • May 2023
            • 235
            • Indianapolis
            #50
            "Don't know how many times I've seen "carb problems" turn out to be ignition problems! " I had that very same thought last night.
            I was definitely peeling back the layers of the onion on this one, so to speak. The collapsed baffle was the cause of my idle/low speed richness, now my high load higher rpm backfires which cropped up at some point in all of this tinkering are (likely) ignition problems. This '78 has truly tested my patience! I'm just glad I have another bike to ride in the meantime.
            I ordered up a supposedly good used ballast resistor on ebay, will test it of course before installing.
              • 813
              #51
              You could always go to 3ohm coils and ditch the ballast resistor all together, it's one less thing in the chain to cause issues although I can also see wanting to continue using Dynatech coils as well.
              • gtem
                • May 2023
                • 235
                • Indianapolis
                #52
                I certainly had that thought, though I want to do some more testing before I commit to buying all new coils. I found a lightly used set of the same orange 1.5ohm style for reasonable money, a new set of Dynas is about $200 these days.
                  • 7818
                  I do have one or two ballast resistors here.I'll check them later today, and I could send one out if you need a "known good" to check with. Just send me a pm.
                  • gtem
                    • May 2023
                    • 235
                    • Indianapolis
                    #54
                    I appreciate the offer Ray! I've got one coming from Ebay-land, hopefully I'll be all set, but I will keep your offer in mind!
                      • 2010
                      If you are measuring that circuit and it is connected, it is possible to read about 3 ohms. You may be looking at the primary side of the coil and the problem could be in the secondary. Cracked/leaky high tension wires. Spray some water on the spark plug wires while it's running and see if there is a change.
                      • gtem
                        • May 2023
                        • 235
                        • Indianapolis
                        #56
                        Deebs I had disconnected the ballast resistor from the connectors when testing it, for what it's worth. And yes the plug wires are under suspicion as well. I can't quite tell if I'm losing one cylinder (plug wire) or two (coil/pickup wire going down). Bike doesn't act up when revved statically, only under load.
                        • gtem
                          • May 2023
                          • 235
                          • Indianapolis
                          #57
                          Latest update: tested my Dyna coils, including putting them in the oven at 180F for a while then retaking measurements, all seemed fine. Checked connections at the plug wires (silicone core, more on that in a bit). Put everything back together with the ballast resistor bypassed. The bike seems to run notably better! Not 100%, but at least 50% better, so I'm moving in the right direction.
                          It was at this point that I realized that perhaps my recent installation of BPR6ES plugs might be the root cause here. I had installed them to replace a mismatched set of old BP6ES and BP8ES that a prior owner had installed, I figured since I had aftermarket non-resistor plug caps that this was the "right" thing to do anyways. I measured the resistance of my silicone core plug wires and they all tested out at around 9 kOhms, per some feedback I got from the XS11 facebook group, many recommend *against* running silicone core wires, and say that the bikes are much "happier" with copper core. So long story short I ordered up both a set of BP6ES plugs *and* a set of copper core wires for the bike. I'll try just swapping over the non resistor plugs first and see if that sorts things out, but then I think I'll switch to the copper core wires anyways as well.
                          So the current working hypothesis is that I inadvertently "choked out" my spark with my new set of resistor plugs, when paired with both a ballast resistor *and* silicone core wires. We'll see!
                          So the full sequence of events went something like this:
                          1. Bike starts running increasingly rich at low rpms, I dive into carbs (it was a collapsed exhaust baffle)
                          2. Went round and round with different jet/needle/etc setups, finally landed back where I started (OEM jetting and needles on '80 Special carbs: #42.5 pilots, #110 mains, 5IZ7 needles)
                          3. Catch the exhaust baffle issue.
                          4. At some point during the carb tinkering, I installed fresh *resistor* plugs
                          5. With the jetting back to what it was and the baffle fixed, I realized my high load "breaking up' was an ignition issue
                          6. Sorting out the ignition now
                          Thanks again everyone for the continuing feedback, and to even just have a place to put my thoughts and share my experiences, maybe some day someone will find this thread and learn something from my tortured multi-month journey to XS11-zen, much like I did with so many old threads on this forum.
                          • gtem
                            • May 2023
                            • 235
                            • Indianapolis
                            #58
                            Hopefully a *final* update on this whole saga:
                            After re-measuring resistances with a better quality multi-meter, I confirmed that a) my current ballast resistor is right at 1.5ohms, b) my dyna 1.5ohm coils do in fact test right at 1.5ohms.
                            I had gotten my hands on perhaps NAPA's last set of four NGK BP6ES in the entire country(!) yesterday, put them on the bike with the current silicone core wires, coils, and ballast resistor hooked back up.
                            HALLELUJAH! The bike runs great
                            , it's never had such clean response down low, rips through the midrange and up top. I had forgotten how potent these bikes are when everything is working right.
                            I still have the copper core wires coming, but I'm going to leave things as they are for now.
                              WoOt! WOOT! gtem! d(⌒ー⌒)
                              THAT's the response owner gets when it runs like the Super Bike it really IS! (✯◡✯)
                              I mean...it's like after every ride imma going, "Day-UHm!!!" (>д<)
                              How did the Yammy engineers get AWAY with making/selling a bike what does this?!
                              ( /・・)ノ
                              NOW you know too. (^_^)
                              Imma thinkin' yur in the minority here fOaR actually followng thru till the positive outcome, tho. (´._.`).。oஇ()
                              Case histories don't show many who overcame this issue- (sorry fOar the XS'ivley long link....)
                              To the VICTOR goes da SPOILS!!! (人´∀`)
                                • 2010
                                Glad you found it. Chasing an electrical problem can be exhausting. You win.
