xs11 run/start issue
  • Tonyxs11
    • Oct 2022
    • 271
    • Cumbria UK
    right the next issue on this problem bike is, when i press the start button it fires up but as soon as i let go of the start button it cuts out !!!!!!! if i hold the start button a few seconds it keeps running. it was fine yesterday but maybe it doesn't like Tuesdays
  • Tonyxs11
    • Oct 2022
    • 271
    • Cumbria UK
    found it, it is a broken wire on the resistor. can it be permanently bypassed ?
      Only if you switch to aftermarket 3 ohm coils, the factory coils are 1.5 and bypassing will stress the TCI.
      • Tonyxs11
        • Oct 2022
        • 271
        • Cumbria UK
        cheers Phil, I can't repair it as its broken low down and very rusty, better get a new one this bike is testing my patience but it was cheap
          Yep, the 78-79 models used the ballast and 1.5 ohm coils, in 80 or 81 they went to 3 ohm with no ballast.
          • Tonyxs11
            • Oct 2022
            • 271
            • Cumbria UK
            cheers for the info, just had a look for another one but nothings available !!!! will keep looking. is their alterative ?
              Not that I'm aware of. Maybe try repairing yours by cutting it open and adding a new wire? If you want to run the engine, bypass the resistor by plugging the 2 wires together. It won't/shouldn't hurt the TCI if it's run just for a few minutes.
              • Tonyxs11
                • Oct 2022
                • 271
                • Cumbria UK
                yeah i'll give it a go
                • Tonyxs11
                  • Oct 2022
                  • 271
                  • Cumbria UK
                  Its beyond repair but managed to find one on CMS
                    Another alternative to a new ballast resistor would be to just upgrade the bike to new 3 ohm dyna coils and then bypass the resistor.
                      Here is the maintenance tip on the Dyna coils. You would want the DC3-1 coils rather then the DC2-1's. Dyna Coil Upgrade - XS11.club Forums
                      • Tonyxs11
                        • Oct 2022
                        • 271
                        • Cumbria UK
                        I thought about that but when I weighed up the cost of a new resister against new coils, the resistor was the cheapest option, this bike is costing me a lot right now and im on a tight budget just trying to get it running good first.
                          You might want to see if you can get the resistor through an auto parts store, my guess is it would be cheaper. On my Goldwing they where $20 via a motorcycle parts house, the local auto parts store had one for $6. There's nothing special about them, just the resistance (ohms) and how many watts they can handle.
                            • 5073
                            I have a spare ballast resistor on the shelf if you still need one.
                            • Tonyxs11
                              • Oct 2022
                              • 271
                              • Cumbria UK
                              thanks for the offer guys but ive already bought a genuine Yamaha one. plus im in the UK.
