Dyna Coil Upgrade
  • sixtysix
    No XS but XSive as can be!
    • 1958
    • Central New York State
    Dyna Coil Upgrade
    Dyna Coil Upgrade
    By Pat Kelly
    4/10/2003
    I was having a problem on my XS1100E with no spark out of my left coil. After testing the coils I determined that this coil was bad and it was time to replace them, so I bought some new Dyna coils. These are from Dennis Kirk.
    Click image for larger version  Name:	20030416-01_dyna_coil_box.jpg Views:	0 Size:	85.7 KB ID:	860765
    Advertised as 6 volt, 1.5 ohm, 35,000 volt output. Tech adviser at Dyna said these would work fine.
    Edit: What has been found to work better is the Dyna DC1-1 'green' coils. By using these, you can bypass/eliminate the ballast resistor on the '78-80 bikes and have a bit hotter 'running' spark (the later bikes come with 3 ohm coils). Same size/shape, so the install is exactly the same other than the minor wiring change for the resistor. To bypass the resistor (located on the left lower frame tube near the coil), simply unplug the two red/white wires from it and connect them together.
    I removed my old stock coils:
    Click image for larger version  Name:	20030416-04stock_coils.jpg Views:	0 Size:	119.1 KB ID:	860766
    Here's a comparison between the old and the new coils:
    Click image for larger version  Name:	20030416-05old_and_new.jpg Views:	0 Size:	125.6 KB ID:	860767
    As you can see when the Dyna Coils are mounted like the stock coils, the plug wires will point to the side (either inside or outside, no room to have the wires facing each other). Here is a coil with the plug wires facing rearward:
    Click image for larger version  Name:	20030416-08rightside_rearward.jpg Views:	0 Size:	97.6 KB ID:	860768
    You can see that the plug wires contact the fuel tank mount.
    Facing forward wasn't much better:
    Click image for larger version  Name:	20030416-09rightside_forward.jpg Views:	0 Size:	104.9 KB ID:	860769
    So I headed to the hardware store and bought some right-angled brackets and some shorter fasteners.
    Click image for larger version  Name:	20030416-03_bracket_and_bolts.jpg Views:	0 Size:	100.0 KB ID:	860770
    These allowed me to mount the coils with the plug wires facing downward:
    Click image for larger version  Name:	20030416-12new_brackets.jpg Views:	0 Size:	102.5 KB ID:	860771
    This routes the plug wires away from everything (like the fuel tank).
    Click image for larger version  Name:	20030416-11wires_angled_down.jpg Views:	0 Size:	107.1 KB ID:	860772
    It's necessary to make some primary wires for the new coils. I snipped the original wires from the stock coils for the color-coding:
    Click image for larger version  Name:	20030416-06wire_from_old_coil.jpg Views:	0 Size:	121.4 KB ID:	860773
    Click image for larger version  Name:	20030416-07left_coil_with_primary_wire.jpg Views:	0 Size:	124.1 KB ID:	860774
    But new wires could be made-up if desired.
    Next came the plug wires. I ordered the Dyna Wires to go with the coils. These wires had straight plug boots that won't work too well, they stick out quite a ways
    Click image for larger version  Name:	20030416-13plugwires.jpg Views:	0 Size:	122.4 KB ID:	860775
    I went to the local auto parts store and bought some right-angle plug boots:
    Click image for larger version  Name:	20030416-02new_plugboots.jpg Views:	0 Size:	134.3 KB ID:	860776
    This makes a much tidier look:
    Click image for larger version  Name:	20030416-15done_left.jpg Views:	0 Size:	131.1 KB ID:	860777
    The finished product
    Click image for larger version  Name:	20030416-14new_setup_top.jpg Views:	0 Size:	126.6 KB ID:	860778
    Another item I bought was Bosch Platinum sparkplugs #4218 and gapped them bigger than stock, .035" (1.12mm). I had the bike running slightly rich before this so I should be dialed-in.
    As it turned out, the coils weren't my problem. I ended-up replacing the ignition box (I wanted these coils anyway).
    I am amazed at the increased power. It's quite noticeable.
    A follow-up problem I'm encountering is it's now harder to start. I'm not sure if the coils are needing more electricity to fire them or if my battery is just going out. I love old bikes.
    Gary Granger
