My speedometer isn't keeping up accurately. Fuel gauge is not working
    Hi Phil, what voltage is that regulator? Do you have a part number for the IC?
      • 8963
      It is 7 volts...
      https://www.mouser.com/ProductDetail...1eF6wy4w%3D%3D
        Thanks Phil. It's great when you can spend $2.00 to avoid a $50.00 part. My problem was the sender and luckily I had a spare. However, when out on a ride I noticed my speedometer was showing incorrect speed and it ended with the unit getting stuck at about 50MPH. It has since returned to 0. I guess I will try the WD40 trick and try not to flood the interior of the meter.
          Worked on the speedometer last night. Made the mistake of removing it from the cluster bracket and in the process ruined the rubber damper gasket because it was so old and brittle. It was only then that I looked around on-line and found that part is not available anywhere. Is there any alternative to the square shaped rubber damper (2H7-83513-01-00)for a standard XS11? Has anyone run into this problem when changing and instrument bulb?
            • 8963
            You can make one from rubber window gasket from Home Depot. It needs to be trimmed down with manicure scissors and it is white, so will need to be painted after installing.
            Click image for larger version  Name:	IMG_20230215_085035~2.jpg Views:	0 Size:	133.8 KB ID:	872219
            Click image for larger version  Name:	IMG_20230215_085640~2.jpg Views:	0 Size:	113.8 KB ID:	872220
            • LenB
              • Nov 2020
              • 160
              • Winnipeg, Manitoba, Canada
              There was hope on the horizon briefly - I was communicating with Sumo Rubber in the U.K. (now closed) last August about making/stocking some square dampers.
              "Hello Len,
              this part is on our list already, we are just struggling to get a sample in good enough condition to send for reproduction.
              Please follow us on social media, we will be announcing any new parts there.
              Thank you for your suggestion!
              Kind regards
              Jackie"
              If someone can source another custom rubber fabricator, other than making some up yourself, that appears to be the only way to get good replicas. Haven't had any luck finding NOS units as I'm sure 40+ year-old rubber, unless stored under pristine conditions, would just rot away to dust.
              On FleaBay - Sold - Behold - the holy grail.....
              And the buyer's feedback....
              "Despite being described as New, I was unable to use the meter dampers because of the AGE of the rubber. They crumbled apart when I took them out of the wrappers. This was entirely my own fault , I should have asked about the condition of the rubber to see if they were still soft."
              1980 XS1100G (one owner-me)
              1984 Honda VF750S V45
              Owned - 1976 XS750D
              Owned - 1972 Honda CB750
              Owned - (unknown year) XS650
                Thank you Phil and Len. I guess this problem has been around for a while. I tried something this morning with neoprene sheets. I cut 1 thick strip and 1 thin strip to build a step in the rubber to closely resemble the original part.
                  Finished product. Looks pretty stock I guess.
                    Good news, speedometer works great! Thanks for the advice.
                      Good speedo repair info:
                        • 8963
                        Nice job. Yep, nice to be able to make your own parts if needed.
