idle mixture screws
    • 2074
    idle mixture screws
    What do you use to adjust the idle mixture screws on your carbs? Any particular brands? I see Motion Pro has a 90 degree screwdriver but will that fit? Or just go to hardware store and get thin standard tip?
    • 8891
    The only reason you would need 90 deg, is to adjust with the tank on, I use a long skinny flathead with the small tip and adjust from above the frame.
    Similar to this...
    https://www.amazon.com/Screwdriver-C...93&sr=8-1&th=1
    Or make your own... Click image for larger version
    • jkorn
      • May 2003
      • 188
      • Wickenburg AZ
      I always take the tank off and flip it around. Front to back.
      Jeff Korn
      Original Owner 79XS1100 E
      • Tim
        • Sep 2022
        • 6
        • West Texas
        I have the motion pro 90 degree tool but use that on carbs with air screw on bottom. On my XS11 i use one of my cut-off short screwdrivers with tank on or a combination of that and a long skinny with tank off.
        Beware when installing a kit, be sure all parts are exactly the same, often they are not. This is why i usually soak all original brass overnight and reuse it
          • 2074
          Jet Kit has been in the bike since around 1986 so no need to change anything around other than cleaning.
