Velcro Carbs
  • LoHo
    • Sep 2002
    • 1342
    • Fresno, CA
    Velcro Carbs
    Has anyone found that the carbs get easier and easier to get on and off the more one does it?
    Yeah, me neither.
  • alaskey2
    • Apr 2014
    • 271
    • 60940
    Have you watched this?
    78 E
      Yeah, me neither.
      They are for from the worst, but yes, I'm picking up what you're laying down. They're actually easier than my XS650.
        https://youtu.be/tsJ3xWA4V7g
        Geoff..Steptoe makes some very good videos and I have watched many of his over the years. This particular one in over 5 years old so I would assume that yes many of us have seen it.
          They are far from the worst. I have had mine on and off so many times over the past two years ... restoring two MNS's that I can have them off in less then 15 minutes. Back on in about the same amount of time. I think it depends on how pliable everything is. Hot bike, warm weather .. versus cold bike cold weather. Fortunately it isn't something that has to be done that often. Really boils down to how well you take care of the bike... ie... fuel filter, gas selection, storage, amount of riding time etc..
            If you really want to find religeon and learn new vocabulary- try removing the carbs on a neglected Honda V65.
            • Bergman16
              • Jun 2014
              • 286
              • New York, N.Y.
              I did it recently three times, following tips on here and Steptoe--Oddly (or not) I had MUCH more trouble with the airbox boots (#3 had dried a bit and shrunk) than the carb holders since I had lubed and warmed them. Not looking forward to doing it again soon, though.
              Steve R
              '80 SG
              Former bikes:
              1978 XS400E Red
              1981 XS850 Special (Stingo)
                Yeah, me neither.
                Hi Larry! Having removed them many a time over the decades, practice makes for quickness. Takes me time-wise approx. 12min. for carb removal, which includes seat, fuel tank and fairing lowers on my bought new 81 Venturer.
                • LoHo
                  • Sep 2002
                  • 1342
                  • Fresno, CA
                  Hey Motoman! I've had them on and off maybe 15 times in the 25 years I've owned Effing Bee. Usually it was on and off three times in a month as I searched out an issue, so it got routine, and then a few years of riding until a long sitting spell gummed them up again. It's been a while so I had some relearning to do.
                    Totally understand LoHo. Just for grins, I*d suggest draining the fuel tank, put some fresh fuel back in tank with a bit of Sea Foam added. Ride the bike some and see it that will help smooth it out a bit before removing carbs for a through internal cleaning.
                    • alaskey2
                      • Apr 2014
                      • 271
                      • 60940
                      My friend calls this the Italian tune up.
                      78 E
                        I have tried that in the past and it didn't work. Well to be honest it didn't work to fully clean the carbs. It did clean the pilot circuit fairly well but when I went out on the bike it had no top end and the bike would only go about 45 to 50 mph. I thought well let me let it sit another day or so and still no top end. When I eventually pulled the carbs the jets really didn't look too bad but the emulsification tubes were fairly gummed up. Of course the ultimate culprit in the whole deal was the fact that like Larry it had sat a while and the gas I was running was ethanol 10. I try to never store the bike with that crap in it anymore. I make sure the last tank I run and the top off tank are ethanol free and then to top that off I put Stabil in the tank and drain the carbs. Has done the trick so far.
                        • LoHo
                          • Sep 2002
                          • 1342
                          • Fresno, CA
                          I appreciate the help, guys. This list is amazing and always has been.
                          For the record, I was not seeking advice, just bitching about the process. Also, I think Seafoam is great maintenance, but once she has sat awhile and runs rough, the whole "triple clean" is the only way.
                            Can you even get ethanol free gas out there? I stay on E0 and ride the bike. I seldom mess with the carburetors. If you have to run E10, then I'm sorry for your luck. It's a real problem for carburetors.
                            • BBQRider
                              • Sep 2017
                              • 51
                              • Asheville, NC
                              I couldn't agree more with Mike (Radioguylogs). Everyone should remove and rebuild a set of carbs from an 80s Honda V4 so they can appreciate how "easy" it is to do an inline four set of carbs!
                              1979 XS1100 F
                              1982 XJ 650
                              1983 XS 650
