Non Air Fork Cap Option
  • Charka120
    • Jan 2021
    • 89
    • SW PA
    I'm upgrading my forks on my XS1100G with Racetech cartridge emulators and heavier springs, so I'm ditching the schrader valve fork caps for solid ones. I had a hard time finding non-air caps that would work.
    So, just in case anyone else wants to do the same I found a very good replacement option. Kawasaki p/n# 44062-010 . It is dimensionally identical to the stock caps but instead uses a solid 22mm hex as can be seen in the photos.
    • 8742
    Good to know this mod, thank you.
    • 2WheelFun
      • Aug 2020
      • 266
      • Pittsburgh PA
      Nice! Glad to see your back on the project. Can't wait to tear up the streets around the Burgh with you. I'll be on the stocker with the pogo stick legs, you know, in your mirror.
      Emulators seem to be the way to go for keeping the cafe look and getting the modern suspension. USD legs just seem too bulky on a stripped down cafe most times.
      1979 XS1100 Special
      1980 XS1100 Std parts bucket
      1987 ZL1000 Eliminator
      • Charka120
        • Jan 2021
        • 89
        • SW PA
        Im excited to do the same. Between about a million things the xs11 build got pushed aside for a few months. Now that swap meet season is over and I've got a few other projects done I'm back on it. Have made a lot of progress, but havent really documented it.
        I decided with the Ohlins on the rear there was no way I could leave the forks stock, but I didnt want to swap front ends though.
          • 7815
          It has the same threads as well? I need to get them myself. I tried searching the part number at Partzilla. No match. Help, please.
            • 2021
            I was pondering that someone who was searching for the origianal caps might be able to mount a schrader valve on those blanks.
              • 7815
              Apparently, the Kawasaki parts are also NLA.
                • 8742
                Those caps would fit a Standard only, they have fine threads, the Special caps have coarse threads.
                  • 7815
                  Thanks! That means the air caps have to stay.
                    • 8742
                    Click image for larger version  Name:	IMG_20211024_214924.jpg Views:	0 Size:	179.9 KB ID:	866905
                    Yep, just went and checked them to be sure, Standard (KYB) air caps are 1.0 thread pitch, Special (Showa) are 1.5
                    Special on the left.
                    • Charka120
                      • Jan 2021
                      • 89
                      • SW PA
                      I should have been more clear. The ones I used are for the standard model which use m30x1.0 threads.
                        • 8742
                        You did state they were for a Standard in your first post...
                        XS1100G is a 1980 Standard.
                        The emulators are great, I have them in both my bikes with Sonic springs.
