I put new springs in at the beginning of 2019 so that's the last time I changed the fluid. I looked on the shelf and I had almost 2 qts of fork oil and it's 15 wt. I changed the oil. The preloads were on the stiffest setting and I put them back there. I went for a ride it still has the wobble the same as before but it is slight. I'm being picky. When I notice something like that it bugs me. lol.
Handle bar wobble with new tires
Originally posted by red bandit View PostI put new springs in at the beginning of 2019 so that's the last time I changed the fluid. I looked on the shelf and I had almost 2 qts of fork oil and it's 15 wt. I changed the oil. The preloads were on the stiffest setting and I put them back there. I went for a ride it still has the wobble the same as before but it is slight. I'm being picky. When I notice something like that it bugs me. lol.2 - 80 LGs bought one new
How does the runout look on the rotors? Maybe one got bent a little when mounting the tire, I've had it happen. I've also got a couple bad front Shinko 712's many years back, I don't use them on the front anymore.2H7 (79) owned since '89
I had a Shinko 712 front tire with a bad wobble. I had to return it and I used another brand in front.-Mike
Originally posted by red bandit View PostI have a Tkat brace.2 - 80 LGs bought one new
I spun the wheel and watched the rotor at the gap at the caliper. I couldn't see any variation in either rotor. When I put the new springs in it was a lot harder getting the fork caps on and I don't have near the sag I used to. It rides nice. It just wiggles a little at 20-30. It's not bad but I know it's there. I think I will ride it for now. The season will be over soon enough. This winter I'll go through the front end thourgholy. Thanks for all your help.79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
79 SF parts bike.
red bandit, you may want to consider putting a hair bit more pre-load on those steerring head tapered rollor bearings.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
The test for correct setting is to raise the front end, and with the wheel centered lightly push one direction on the handlebar. The front end should smoothly fall to the side, but NOT quickly. Do both directions, and then slowly go lock to lock with the bars, feeling for any "snags" or sticky spots.Ray Matteis
Originally posted by DiverRay View PostThe test for correct setting is to raise the front end, and with the wheel centered lightly push one direction on the handlebar. The front end should smoothly fall to the side, but NOT quickly. Do both directions, and then slowly go lock to lock with the bars, feeling for any "snags" or sticky spots.Last edited by Bonz; 08-24-2021, 10:31 PM.Howard
ZRX1200
Tires are directional. Do you have the arrow pointed in the direction of travel?"Galaxy" 1982 XJ1100J, 1983 XV handlebars, new fusebox, homemade SS wind screen and SS muffler heat shields, homemade grab bar extension and luggage rack. XS750 140 mph speedo, '81 Venture oil cooler, V-Max ACCT, Yahman YICS Eliminator, 1st and 2nd gear Dremel fix.
