Handle bar wobble with new tires
  • red bandit
    • 970
    • central michigan
    I put new springs in at the beginning of 2019 so that's the last time I changed the fluid. I looked on the shelf and I had almost 2 qts of fork oil and it's 15 wt. I changed the oil. The preloads were on the stiffest setting and I put them back there. I went for a ride it still has the wobble the same as before but it is slight. I'm being picky. When I notice something like that it bugs me. lol.
    79 SF parts bike.
      If you don't have a fork brace ...that would probably be a good next step. Tarozzi makes one that will fit your standard. Fork Brace Yamaha XS1100 | Yamaha Motorcycle Parts | Mikes XS
      • red bandit
        • 970
        • central michigan
        I have a Tkat brace.
        79 SF parts bike.
          • 8962
          How does the runout look on the rotors? Maybe one got bent a little when mounting the tire, I've had it happen. I've also got a couple bad front Shinko 712's many years back, I don't use them on the front anymore.
            I had a Shinko 712 front tire with a bad wobble. I had to return it and I used another brand in front.
            • speedlimit85
              • Jan 2017
              • 492
              • Gainesville, Fl.
              A bad tire can shake the handlebars.
              80 G
                Sounds like you have all the bases covered ... yet you still have wobble. You described wobble even before the new tires. Might want to try stiffening the forks with progressive springs. You sated you are running with a fairing, which adds a bit more weight up front. Progressive springs with more air pressure in the forks might stiffen them enough to take some of the play out of them. How big of a guy are you? The reason I ask of course is from the weight perspective. One of the biggest draw backs on these old 11's was the weak front end. For the day though most all bikes had that very same problem. If I were you I would go back through everything on the front end .. .including the steering bearings. Check the bearings and the races. Then work your way down from there. If you find no problems I would upgraded the fork springs to stiffen the forks. At least that would alleviate the bounce in them. Not a easy endeavor for sure and might be a good winter project. For now while the weather is permitting just ride it.
                • red bandit
                  • 970
                  • central michigan
                  I spun the wheel and watched the rotor at the gap at the caliper. I couldn't see any variation in either rotor. When I put the new springs in it was a lot harder getting the fork caps on and I don't have near the sag I used to. It rides nice. It just wiggles a little at 20-30. It's not bad but I know it's there. I think I will ride it for now. The season will be over soon enough. This winter I'll go through the front end thourgholy. Thanks for all your help.
                  79 SF parts bike.
                    red bandit, you may want to consider putting a hair bit more pre-load on those steerring head tapered rollor bearings.
                    • red bandit
                      • 970
                      • central michigan
                      Will do. Thank you.
                      79 SF parts bike.
                        The test for correct setting is to raise the front end, and with the wheel centered lightly push one direction on the handlebar. The front end should smoothly fall to the side, but NOT quickly. Do both directions, and then slowly go lock to lock with the bars, feeling for any "snags" or sticky spots.
                          • 3373
                          The issue I've come across with this method is there's no weight on the front end, obviously. The bearings have worn from being in use or pitting with weight upon them for a long period of time, not suspended off the ground. With no load on them they may not show the signs you were looking for. A method I have heard is to take a piece of wax paper, put it on the garage floor, roll the front tire onto it. Now do the same test as described above while straddling the bike. How easily do the bars move left to right, and is there any roughness or notchiness. JAT.
                          2001 ZRX 1200
                          1982 Seca 750
                          1983 Nighthawk 550
                          • XJkid
                            • Jun 2003
                            • 281
                            • Elk Grove, Ca.
                            Tires are directional. Do you have the arrow pointed in the direction of travel?
                            • red bandit
                              • 970
                              • central michigan
                              The arrows are pointed in the correct direction. Thanks. I'll go thru everything this winter. Not much riding season left.
                              79 SF parts bike.
