Big Mistake...Please advise
  • jpiombo67
    • May 2021
    • 33
    • Traverse City, Michigan
    Total noob. Went to change the oil today and drained the middle drive oil instead of engine oil.
    Long story short, bike ran for about 1 min. Smoke everywhere and oil leaking from air box valve.
    I drained the oil, cleaned out air box
    Tomorrow I’ll be purchasing oils for both engine and middle drive.
    Question how much damage did I do?
    will it be safe to start the engine .
    1979 xs1100
    2017 CRF 250 Rally
    1979 XS 1100
    1985 Porsche 944
    1991 Alfa 164
  • FJ111200
    • Oct 2007
    • 317
    • Crewe, Cheshire, UK
    If you only ran it for a minute it'll be alright. Just oil overfill exiting the engine. Middle gearbox should be alright too as long as it wasn't ridden hard. It takes a lot of abuse to fook an engine.
      Use a new or very good allen wrench on the middle drive!! If it does not want to turn, try heating a little bit with a heat gun or propane torch. You want the case warm, and the bolt cold so it will start turning a little easier.
      Do pick up synthetic 70-140 gear oil for the middle drive. We proved a long time ago that it kept the heat down. Less heat, less friction and less wear.
      • jpiombo67
        • May 2021
        • 33
        Thank you all.
        Both engine and middle drive oils replaced. To manual specs. Ordered new air filter, the one in the now is a bit oily from my disastrous debacle.
        Took a few turns to get the machine to fire up.
        Smoke was coming from exhausts, but went away after a couple of slow loops around my block.
        Let the the machine rest for a few hours, started Up, but still smoking. I let it idle for about 3 minutes and smoke went away. No seepage anywhere. Engine is dry.
        I imagine it is residual oil from the large quantities I mistakenly put in the crank case
        2017 CRF 250 Rally
        1979 XS 1100
        1985 Porsche 944
        1991 Alfa 164
          • 8962
          Take a longer ride and it should totally clear up.
          • jpiombo67
            • May 2021
            • 33
            I will. Needs to warm up. 40’s at the moment. Lol. Lucky you that lives in Florida.
            2017 CRF 250 Rally
            1979 XS 1100
            1985 Porsche 944
            1991 Alfa 164
              • 8962
              Yep, high 70's here at midnight. BTW, what is a limited edition? It says that in your signature.
              • jpiombo67
                • May 2021
                • 33
                Bikerphil... not quite sure it says it in the badge. I’m going to research the vin and see what I come up with.
                2017 CRF 250 Rally
                1979 XS 1100
                1985 Porsche 944
                1991 Alfa 164
                  • 735
                  That's interesting, would love to see it...... could you post a picture of that badge?
                  Thanks,
                  • jpiombo67
                    • May 2021
                    • 33
                    Here is the picture of the badge. Possibly an aftermarket build? VIN number reflects base trim
                    2017 CRF 250 Rally
                    1979 XS 1100
                    1985 Porsche 944
                    1991 Alfa 164
                      • 735
                      That's a cool badge and a great looking bike, thanks for posting pics.
                        With the color, I would guess Bob Jones had a hand in that bike. Check the rear shocks for a sticker from Merriam Cycles.
                          The gold detail on the side covers look like this bike, which was just purchased by one of our members in Traverse City, Michigan:
                            Mike, look at the tank, it has the same "logo". Karla may remember if Bob did something like that for a "touring" look machine.
                              • 735
                              And the same front fender and same seat... looks like the same bike to me!
