5.2k rpm wall.
    • 2160
    I has a similar problem with two of my XS750's independently. They ran fine until the RPM got to 5k, the they would stumble and RPM would not increase.
    In both cases, the main jets were clogged with corrosion. It was strange because in both cases, the carbs had been rebuilt 2-3 years before the incidents.
    This happened during a period when I drained the carb bowls for winter storage. Believe it or not, I have not any more trouble (yet) since I stopped draining the carb bowls for storage about 6 years ago.
    I don't know if this is related to your problem, but it's more information for you.
Name:	Carb 1 small.jpg
      • 9981
      3 things that I've experienced causing similar issues. 1) restricted exhaust will cause RPMs to flatten due to back pressure 2) pinholes in slide diaphragms not allowing slides to go up far enough 3) Slides improperly clocked after diaphragm replacement. There is a small air bleed hole in the slide that has to be directly front and center engine side in order for the slides to work correctly. Just tossing those out there as things to check.
      • Banshee's Veil
        • 104
        Ditto on the exhaust. No wall without it. I was running a cheapo Amazon basics pipe. Straights are just too loud. Need to get an exhaust with no back pressure.
          • 9981
          Yeah. My bike HATES back pressure an altitude above 8000 feet. I bought a MAC flare tip exhaust and put straight through perforated baffles wrapped in SS steel wool in it.
