Newbie questions on jets and clutch
  • Twinzer
    • May 2021
    • 36
    • Bay Area, San Francisco
    Hi there - I just picked up a non-running 1979 XS1100F and have been enjoying reading all of the information on this site.
    Couple of questions;
    I cleaned the carbs and noticed that it has size 110 main jets with individual pods. It does have the older style 1979 carbs as I checked just in case. Reading the information here, the main jets should be 137.5 - this is a California bike - is there anything different with the cali models or did someone put in the wrong jets? Also, I presume with pod filters, I would need to upsize to 145 (everything else stock).
    Second question - I tried pushing the bike (not started) in gear with the clutch pulled in and it would not roll. Question is; is this normal for this bike (does it need to be running?) or do you think the clutch plates are stuck?
    Any help much appreciated.
    • 2007
    as for the jetting I would go by this post as a guide. Not the gospel mind you but as a guide. Jetting Recommendations - XS11.club Forums
    The second question ... these bikes are very hard to push to begin with, however with the clutch pulled in you should be able to move the bike. would be easier to check with the bike running and everything rotating then use the clutch to disengage the transmission and try to move it. If you suspect the plates are stuck it is not that much work to remove the clutch cover to inspect.
      • 7831
      Jets, check and see if you still have the '79 carbs! Someone MAY have changed to the later model, and you would have smaller main jets.
      Clutch, park the bike on the side stand and remove the cover, then remove the plates. Clean up the steel and check the fiber, but they probably are good, just stuck. Replace the springs with BARNETTE springs, NOT any other brand except stock. You will need to pull the right foot peg to pull the cover.
      Welcome to the site!
      • Twinzer
        • May 2021
        • 36
        Thanks both. I did check because I thought of that too and I do have the 1979 carbs - good info on this site was able to help me there.
        For the clutch - on the side stand, I presume you don't have to empty the engine oil and that nothing will leak once you take off the full cover - is that correct? Also can I reuse the gasket on the engine cover or have to replace?
          • 7831
          If the cover/gasket is good when you remove it, you can just smear some non-hardening permatex to keep it from leaking.
          For the jets, I would go through the carbs and check everything. Make sure to use ONLY genuine Mikuni jets! Using K&L, or any other jet WILL cause problems.
          • Twinzer
            • May 2021
            • 36
            Thanks Ray - yep for sure
              I would say that you are correct or nearly correct with the things you said. I would be very suspicious about the carbs being earlier model with 110 mains.
              Pod filters are a pain in my book. I had K&N oval filters and 145s if I remember correctly but I also had a 4 into 1 header. The cheaper round filters are prone to block the holes at the carb inlets. The older carbs will have vent hoses above the fuel hoses. Make sure the vent hoses aren’t blocked or the carbs will flood. Yeah, sticky clutch plates is common for a bike that has been sitting. Eventually they will relax as they are worked.
