Gas in airbox, petcock OK
  • LenB
    • Nov 2020
    • 160
    • Winnipeg, Manitoba, Canada
    Yanked out all pollution control crap (part #28) , sealed the holes on the airbox and just ran the breather to the ground - has had no impact on operation - possibly improved. Not a critical component as far as I can see. This part is abandoned when you install an aftermarket intake, anyway.
    1980 XS1100G (one owner-me)
    1984 Honda VF750S V45
    Owned - 1976 XS750D
    Owned - 1972 Honda CB750
    Owned - (unknown year) XS650
      • 7832
      Yeah, but down here we need to put a filter on it to keep the bugs out.
      • cnap504
        • Dec 2020
        • 56
        • Louisiana
        I like keeping the original air box in place but I have neither the patience or skill to pull the carbs and put them back when retaining the oe air box. And when getting a long term non running bike back running the carbs may have to come off and on a couple times, another reason I can’t deal with the air box. I have a 15 year non runner now up and running and any thing that prevents the fuel float needles from sealing will cause fuel spill. I had an issue with the float brackets binding on the float “axles”. Anything that inhibits the float needles from sealing can be a problem, I’d like to keep the airbox but sometimes it gets in my way.
        I’m running cheap individual air filter pods, shimmed stock slide needles .025”, 42.5 pilots, 3 1/2 turns out on the fuel screws and 142.5 main jets. Might not be the way you want to go but it worked for me. Also ditched the dual vacuum petcocks and their maze of pipes, now running a single manual petcock
          • 2007
          did you employ some sort of filter or anything to catch the oil or do you just allow it to go out on the road?
          • MPittma100
            • Aug 2011
            • 2359
            After you get the carbs right, there is a mod to the petcocks that will allow you to turn the fuel off mechanically. Get new Mikuni float valves and put gas in carbs off engine to check for leaks.
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
