Anybody recognize this?
    I have measured for stiction on several pairs of Standard forks and always found a lot of it, no matter how perfectly alligned they were, even without a brace. This led to an FJ fork conversion. Problem solved. BTW, forks on a Special don't have this particular issue. That's a whole another story.
    • dbbrian
      • May 2016
      • 596
      • Stratford, Ontario, Canada
      Please tell me how you did the measurement Phil
      Brian
        Brian, I pretty much just put a cable tie around the stanchion flush with the rubber dust seal. Push down on the handlebars to compress the suspension and then release. Measure the distance between the two, then pull up and extend the suspension and release. Now measure the distance between the two again. If there is no stiction, the number will be the same, otherwise subtract the lower number and that is how much stiction you have.
        • dbbrian
          • May 2016
          • 596
          Thanks. I just checked a few times - don't think I have stiction problems
            Awesome, you can consider yourself lucky.
              If you have an XS1100 standard, you can get a Tkat style brace from Fastec-Racing. JeffH may be able to tell you which one fits.
              • somesuch
                • Jun 2007
                • 145
                • San Jose CA
                using the cable tie as mentioned above, I push down on the bars an gently let the front end settle.I then slide the cable tie down to the seal scraper. I then pull up on the bars,and again, gently let the front settle. Now measure the distance between the top of the seal scraper and the cable tie. 5mm is great on modern forks....my xS11 bikes usually were about an inch, maybe a tad more. Single lip NOK seals would really make a difference
