Stainless Steel Brake Lines
    • 1967
    I am just curious what and where you are getting your lines from? I am aware that xj4ever supplies them. Just looking for alternatives. Suggestions?
    • 8054
    I bought some from Z1 Enterprises before the buyout. I assembled them myself. Earlier I bought some from a company apparently no longer in business called Bremzen. Their product was garbage and so were they. I’ve also installed the lines from XJ4Ever without complaint.
      • 8863
      I just bought some universal lines and ends from Dennis Kirk. The banjo fittings thread into the lines with AN #3 fittings so you can clock them any way you like. Good quality.
      • MarkD
        • Jun 2013
        • 488
        • N. Michigan
        Ian MacDonald has a great post, and we got ours from: https://www.technafitstore.com/searc...&Search=xs1100
        There is a whole kit for our xs11s, and this link is working. If you have a question, search: https://xs11.club/forum/idle-talk-fo...ed-brake-lines
        Hope this helps--
        M.
        79 F
        1967 Suzuki X6 Hustler
        1973 Suzuki TM 125
        1979 XS1100 F
        2005 Kaw. Vulcan VN800
        1991 BMW K75
          • 7795
          On the Special, I had a local shop build them. They are a hydraulic shop, so have all the high pressure as well as DOT approved lines. I did cost about $200 for all lines, front and back.
            • 1967
            Hope this helps--
            M.
            Good info. Keep them coming.
            • Bax
              • 344
              • Merrimack, NH
              I changed my bars so I adjusted the length and hard pipe angle on the upper banjo fitting so I went custom. All brake lines replaced on the bike at same time. Galfer USA. was the supplier.
              ---Bax
              • roidfingers
                • Dec 2020
                • 1
                • Tuscaloosa
                11 in-78 in Motorcycle Braided Stainless Steel Brake Clutch Oil Hose Line US | eBay. Have used these on 2 different bikes. Work great. Never a problem
                  • 1967
                  thanks for this post... basically you can measure and get the bikes done for way less the 100 bucks. good find.
                  • BBQRider
                    • Sep 2017
                    • 51
                    • Asheville, NC
                    Hey Cajun, I’ve done several bikes by just measuring the old lines and then ordering either Russell brand and Goodridge lines and ends from J&P Cycle. I’ve found they both work well but the Russell seem to be a little more compliant to work with. Definitely some of the best money spent on a bike IMHO.
                    1979 XS1100 F
                    1982 XJ 650
                    1983 XS 650
                      • 282
                      DITTO on Roidfingers response,,,,EBAY rocks for ss lines,https://www.ebay.com/itm/11-in-78-in...Oil-Hose-Line- ,do a bike for under 40.00, have done 5 xs, various motors,,,lines are good, cheap, easy fit, just measure old lines, pick color, get a bottle of new brake fluid,,,and your xs will love you with nice solid braking........Mike in Sun Diego
