TECHNA-FIT S/S Braided Brake Lines
    • 3918
    Introducing: Techna-Fit S/S Braided Brake Lines
    I was looking for an alternative vendor for stainless steel braided brake lines and saw a fellow forum member suggest Techna-Fit. I clicked-on the link and saw that they fabricated customized lines. I was clueless as to clocking, banjo angles, etc., so I sent Chris Herman, Techna-Fit's Operations Manager, an email (chris@techna-fit.com). I relayed my concerns to Chris regarding the lines, and the specifications I was looking for. Chris quickly responded, and asked that I send in the lines for the best fit for my bike.
    A week later and look what shows-up on my door step via UPS:
    Package Invoice:
    Package Contents:
    And, nicely sealed, original lines and S/S lines:
    Included in the Kit are four lines, one from the Master Cylinder to the Splitter, two lines from the splitter to the respective calipers, and a completely original one-piece line going from the rear Master Cylinder to the rear caliper:
    Also included in the kit, banjo bolts and copper washers:
    Here are the lines compared to the original lines:
    As you can see, Techna-Fit even duplicated the mounting bushings for the front and rear lines.
    I found that after ordering these lines from Techna-Fit, they made it even easier for us XS owners to attain these lines by using their website @ http://www.technafitstore.com/category-s/41044.htm Click-on "Vintage Motorcycle" in the left-hand side of the screen, and then click-on "YAMXS1100F ". This will take you to the following screen:
    Click-on "Add to cart", and those lines will be to you door in no-time! Of course, if you have any concerns, questions, or comment, Techna-Fit would love to assist you. You may contact them via any of the means below:
    Headquarters, Manufacturing and Assembly Plant
    Office Hours: 8am to 5pm Eastern Time
    Address: 486 Southpoint Circle, Suite 104, Brownsburg, Indiana 46112
    Telephone: 317-350-2153
    Fax: 317-350-2164
    Stuart Trotter - President
    Email: stuart@techna-fit.com
    Chris Herman - Operations Manager
    Email: chris@techna-fit.com
    Lani Trotter - Advertising & Marketing
    Email: lani@techna-fit.com
    I look forward to the Spring-time and seeing how great these lines are. Happy stopping.
  • MarkD
    • Jun 2013
    • 488
    • N. Michigan
    Hey Ian-- these lines look like a fairly perfect match. I am interested in your install, as to a final say on fit and finish. Was there a problem with your old lines, or are you doing a better safe than sorry replacement? I know there was a long thread on old rubber lines. Mine look good, I pulled hard on the lever, and felt no swelling on the lines, as someone had suggested, but I'm thinking S. Steel may be a good insurance policy against line failure.
    79 F
    1967 Suzuki X6 Hustler
    1973 Suzuki TM 125
    1979 XS1100 F
    2005 Kaw. Vulcan VN800
    1991 BMW K75
      • 3918
      Well, you could probably go the rest of your riding days with OEM lines with minimal issues. BUT, the fact that the manual says to replace every FOUR years, and this bike is 35 years old, means that it should have had almost nine sets of lines already. Rubber breaks down, and you & I know that to be fact. At what point in your 80 mph riding do you want to find-out how long it takes 35 year-old OEM lines to spring a leak? Also, this is the first year I have extra money that is not paying for this or that, etc. So, it's time to pamper the XS. Also, the raw stopping power of brake lines that don't swell versus our lines was my ultimate reason behind switching over. You say you don't see swelling, but I can almost guarantee it's happening. I'll mount these lines after all of the other mods are complete.
      • rdmcguy
        • Jul 2013
        • 515
        • Denver, Colo.
        SS brake lines
        Hello all !!
        A big round of applause for Ian for finding a source for reasonably priced
        ss brake lines,
        Ian,I see that you use superbiker handlebars.
        Did you have the upper line reduced in length to accommodate for them or just go with stock length?
          • 3918
          RD- I have used stock length brake lines on all bars I've had on here (OEM, Euro, Daytona, Superbike), so I saw no issues going stock length with the S/S lines. We'll see though.
          • MarkD
            • Jun 2013
            • 488
            • N. Michigan
            Point taken, Ian. Looks like a set of these lines are in my future. Thanks for the info and finding a good source for the lines.
            79 F
            1973 Suzuki TM 125
            1979 XS1100 F
            1991 BMW K75
            • MPittma100
              • Aug 2011
              • 2359
              SS Lines
              Hi Ian,
              +1 here on a job well done. I and others have paid "through the nose" for these lines from other sources. It is good to see what appears to be a very good product for considerably less [/B]cost than I have paid to another vendor. The next set(s) that I need will be ordered form Techna-Fit.
              Mike
              1981 XS1100H Venturer
              K&N Air Filter
              ACCT
              Custom Paint by Deitz
              Geezer Rectifier/Regulator
              Stebel Nautilus Horn
              EBC Front Rotors
              Limie Accent Moves On In 2015
              Mike
              • Newbee
                Truly XSive (Deceased)
                • Jul 2011
                • 160
                • Whitby Ontario, Canada
                Received TechNa-Fit Brake Lines
                http://s1260.photobucket.com/user/ke...ee7a8.mp4.htmlI thought of doing it this way so I didn't load the thread with a lot of pictures and writing just click stop to read posting. Maybe Ian can post his actual measured lengths again mine are for the 79F to try on 80G.
                  • 3918
                  Good video Newbee! But, who the heck doesn't like pics, lol? I have not even attempted to check to see if they fit or not. My hope & prayer is that they do, or I will make them
                  • MarkD
                    • Jun 2013
                    • 488
                    • N. Michigan
                    OK, Ian, just ordered the TechnaFit lines. Looking forward to a 'peace of mind' change in my system. Thanks for helping to get these available for us XS owners.
                    79 F
                    1973 Suzuki TM 125
                    1979 XS1100 F
                    1991 BMW K75
                      • 3189
                      Ian, I do hope you have tried them by now. How did they fit? Just want to be sure of the fit, so not too many order them on a "hope and a prayer". I am extremely happy if they fit as I did not much like the price of the ones I did, but what does one do? If they are a good fit and are cheaper then I am not allergic to trying them myself.
                        • 3918
                        Hey Ras- Yes, they fit great. I think the rear line rubbers may be backwards, but that was not a concern for me. Also, for the front rubbers, the stock mount brackets are too wide, so you have to figure something out regarding that.
                          I have a set of lines of a special, all but the line from the front MC to the splitter. I'd be happy to send them in if they would be beneficial. May even pull the front MC line off the SG, still need to get that exhaust fixed and painted before it is ready to ride anyway.
                            • 3918
                            Hey Don- The company is right next-door in Indiana, so it would not take long for them to hold your lines . . .
                              Heck, I'll just drop them off on my next trip to Chicago or even Indy.
