Completely dismantled motor to put in new cam chain. installed new rings lapped and shimmed valves to spec. Motor is running good but on highway won't go over 74 mph. It has pod filters on carbs and an 80s Jarden exhaust system I am thinking it is a carb issue any suggestions
bike doesn't perform like it should
#1!! What year and model is the bike?
The early bikes have a mechanical advance system, as well as the vacuum retard that needs to be connected to the #2 carb(2nd from left when sitting on the bike).
What pod filters do you have? Some are KNOWN to cause problems because of the design!
How much fuel do you have in the tank? Specials do NOT run well when low!!!
With a little more info, we should be able to give you someplace to start looking for your problems.Ray Matteis
XS1100 SF Bob Jones worked on it! -
2004 Kawasaki Concours. ( Black Bear)Comment
Hi Gord, A few things to check. The wires going to the timing pickups are a known weak point and break inside the insulation on the loop back. While you have the timing cover off make sure the advance rotates freely. IFRR 75mph is like 5000 RPMs in 5th which is at the max advance. On bikes with mech advance timing I've read that folks had similar issues when an ignition box from 80 and up were swapped into the bike, need to verify part numbers. Can you achieve higher RPMs in lower gears or does it stumble consistently at the same place on the tach?
---Bax80 SG, --- Slightly modified with EFI.....Comment
Try a run with the petcocks set to prime. That runs off the front lines, and if you do have a kink in the line, that may help it to run. Do just one side, test, then the other. That should let you know if it's only one line. I know I STILL have some feed problems on my '79SF, Left side only, and I've played with it all summer...Last edited by DiverRay; 10-27-2020, 09:02 AM.Ray Matteis
FWIW, I have a Jardine 4 into 1 on mine. It performs very well, IMHO.Marty (in Mississippi)
XS650EComment
Thanks for you advice went through fuel system. the carbs were rebuilt. Pulled off pod filters revved up engine only one of the sliders moved. Moved them manually and only the one comes down slow the other three just drop down. I assume I have to replace diaphragm.Comment
Hi Gord, Those diaphgrams are available from JBM as a replacement part. I've used them, there on my bike.
JBM Industries rubber carburetor holder socket boots, flange intake sockets, vibration isolators, stainless steel exhaust springs, for Rotax 912, 582, 503, 447, 377, Zenoah & HKS engines. Yamaha 650 SX and TX Mikuni BS-38 and 34 CV carbs. Diaphragms & holders.
80-81 YAMAHA XS1100 CARBURETOR SLIDE PISTON & RUBBER DIAPHRAGM
At $20 each, these are going to be tough to beat. They came up on another forum. No complaint listed. The diaphragm is as original.
XS650EComment
Simple and maybe silly thought here... Are the diaphragms sealed around the top of the carb body and in their groove correctly? If they are not in the groove and seated properly they will do what you described.Howard
ZRX1200
BTW, ZRX carbs have the same spacing as the XS11... http://www.xs11.com/forum/showthread.php?t=35462Comment
