Wtf is this
  • Banshee's Veil
    • 104
    Wtf is this
    I'm using to oil and liquid cooled bikes. What is this thingy?
  • dpotter58
    • Aug 2004
    • 1866
    • Southern Maryland
    Cam chain tensioner
    1980 LG
    1981 LH
    • Banshee's Veil
      • 104
      Cam chain tensioner
      Ah thank you
        • 7836
        Check the modification section, as you should replace it with a newer ACC.
          • 8937
          Do not remove that "thingy" without following the procedure in the service manual, if the timing chain skips you will bend valves, these are interference motors.
          • jkorn
            • May 2003
            • 188
            • Wickenburg AZ
            They are easy to adjust.
            Jeff Korn
            Original Owner 79XS1100 E
            • dpotter58
              • Aug 2004
              • 1866
              • Southern Maryland
              and easier to eff up.
              1980 LG
              1981 LH
                • 7836
                They are the weakest part of the engine, IMHO. I've put units from the Venture/VMax into the engines I own. I did have one of the original units loosen up after a "fast" run through some fun roads.
