If that spring is fairly small...like the diameter of a "bb" and evenly round like a cylinder, then it belongs behind your choke lever ROD in the carb body, it's used with that "bb" for the detents on the choke lever!
79SF "The Teacher" . . .basket case! History shows again and again,
Petcock DOES have a spring. Goes by the vacuum diaphram. Spring holds the diaphram plunger forward to stop fuel flow till vacuum suck diaphram and plunger back to open flow.
The sandwich is: petcock assy, plunger and diaphram gasket, plastic block, diaphram, spring, and then the back plate with vacuum hose nipple.
Unless you have a special... I don't know what they look like.
(I tried the link to see the pic, but I couldn't get it)
The standard petcock does in fact have a spring inside. It is approximately 1/4" diameter by maybe an inch or so long. It goes on the dry side of the diaphragm to push the sealing o-ring against a seat to shut off fuel flow when there is no vacuum.
Prometheus and I are talking about a petcock on a Standard - it definitely does have a spring. John was talking about a petcock on a Special - it definitely does not have a spring.
