Does a petcock have spring inside?
  • tokarz33
    • Mar 2005
    • 34
    • Lucas, TX
    Does a petcock have spring inside? I ask because I have an extra spring on my work bench.
    www.yamaha-motor.com does not show a spring.
    Thanks,
    Andrew
    They have a wavey spring/washer, but no coiled spring.
    • tokarz33
      • Mar 2005
      • 34
      • Lucas, TX
      Cool, thanks. I better save that spring.
        hey tokarz
        Where is Lucas?
        • tokarz33
          • Mar 2005
          • 34
          • Lucas, TX
          on 1378, 4-5 streets south of the lucas food mart. been out here before?
            Hey Andrew,
            If that spring is fairly small...like the diameter of a "bb" and evenly round like a cylinder, then it belongs behind your choke lever ROD in the carb body, it's used with that "bb" for the detents on the choke lever!
            • tokarz33
              • Mar 2005
              • 34
              • Lucas, TX
              Bingo!! Maybe that is why my chock does not stay open.
              Carbs are all rebuilt. Bike started up no problem. I was surprised. Engine has a cool sound.
              Tomorrow night I will synch the carbs. All that is left is restoring the rusty tank.
              • prometheus578
                XS-XJ Super Guru (RESIGNED)
                • Aug 2004
                • 4012
                • Olympia , Wa.
                petcock spring
                Petcock DOES have a spring. Goes by the vacuum diaphram. Spring holds the diaphram plunger forward to stop fuel flow till vacuum suck diaphram and plunger back to open flow.
                The sandwich is: petcock assy, plunger and diaphram gasket, plastic block, diaphram, spring, and then the back plate with vacuum hose nipple.
                Unless you have a special... I don't know what they look like.
                (I tried the link to see the pic, but I couldn't get it)
                • tokarz33
                  • Mar 2005
                  • 34
                  • Lucas, TX
                  I do have two springs. One from the carbs and I was pretty sure this other one came from the petcock. Parts diagrams do not show the spring though.
                    Oops
                    I didn't realize that you rode a standard. I was refering to a Special. Sorry 'bout that.
                    • tokarz33
                      • Mar 2005
                      • 34
                      • Lucas, TX
                      Thanks. I still have two springs. One for the carb and one for something else. This is so much fun.
                        The standard petcock does in fact have a spring inside. It is approximately 1/4" diameter by maybe an inch or so long. It goes on the dry side of the diaphragm to push the sealing o-ring against a seat to shut off fuel flow when there is no vacuum.
                        • tokarz33
                          • Mar 2005
                          • 34
                          • Lucas, TX
                          Ok guys, I am getting mixed signals. Which is it? Could someone check their manual?
                            Prometheus and I are talking about a petcock on a Standard - it definitely does have a spring. John was talking about a petcock on a Special - it definitely does not have a spring.
                            Which model do you have?
                            • tokarz33
                              • Mar 2005
                              • 34
                              • Lucas, TX
                              81 xs1100 H Model
                              standard right?
