Does a petcock have spring inside?
  • Does a petcock have spring inside?
    Does a petcock have spring inside? I ask because I have an extra spring on my work bench.
    www.yamaha-motor.com does not show a spring.
    Thanks,
    Andrew
    They have a wavey spring/washer, but no coiled spring.
      Cool, thanks. I better save that spring.
        hey tokarz
        Where is Lucas?
          on 1378, 4-5 streets south of the lucas food mart. been out here before?
            Hey Andrew,
            If that spring is fairly small...like the diameter of a "bb" and evenly round like a cylinder, then it belongs behind your choke lever ROD in the carb body, it's used with that "bb" for the detents on the choke lever!
              Bingo!! Maybe that is why my chock does not stay open.
              Carbs are all rebuilt. Bike started up no problem. I was surprised. Engine has a cool sound.
              Tomorrow night I will synch the carbs. All that is left is restoring the rusty tank.
                petcock spring
                Petcock DOES have a spring. Goes by the vacuum diaphram. Spring holds the diaphram plunger forward to stop fuel flow till vacuum suck diaphram and plunger back to open flow.
                The sandwich is: petcock assy, plunger and diaphram gasket, plastic block, diaphram, spring, and then the back plate with vacuum hose nipple.
                Unless you have a special... I don't know what they look like.
                (I tried the link to see the pic, but I couldn't get it)
                  I do have two springs. One from the carbs and I was pretty sure this other one came from the petcock. Parts diagrams do not show the spring though.
                    Oops
                    I didn't realize that you rode a standard. I was refering to a Special. Sorry 'bout that.
                      Thanks. I still have two springs. One for the carb and one for something else. This is so much fun.
                        The standard petcock does in fact have a spring inside. It is approximately 1/4" diameter by maybe an inch or so long. It goes on the dry side of the diaphragm to push the sealing o-ring against a seat to shut off fuel flow when there is no vacuum.
                        Ken Talbot
                        • #13
                          Ok guys, I am getting mixed signals. Which is it? Could someone check their manual?
                          • #14
                            Prometheus and I are talking about a petcock on a Standard - it definitely does have a spring. John was talking about a petcock on a Special - it definitely does not have a spring.
                            Which model do you have?
                            Ken Talbot
                            • #15
                              81 xs1100 H Model
                              standard right?
