Carbs again??? Or still!!!
  • GNEPIG
    • Apr 2005
    • 1656
    • fl
    .. ok Noeleo, i have found the solution to my cold start problem!
    yee fukin hoo!!
    i have been reading this thread from the start and it sounds just like thee same problem that i've been having with my bike right after i changed my float bowl gaskets ..
    .. i put new gaskets on and this is how they looked when i took them out of the package
    .. so i punched out the holes that i thought would work like this
    .. i had starting problems ever since.. so tonight i was looking at what could be the problem again and noticed i had not removed the plug at the other end of the transfer port on the float bowl. low and behold this was my problem, it starts just like its supposed to cold now full choke no throttle
    .. this all sounds pretty weenie but this might be your problem also.. if by chance you have removed this last plug already then make sure that the little hole in the carb above this hole is clear.. apparently this is some kind of a passage that conects to the little hole in the brass choke straw, maybe a vent
    .. i hope this helps.. let us know
    • Winterhawk
      • Jun 2004
      • 684
      • Missouri
      LOLOLOL, Excellent.
      Like Ken said, choke holes. 9 out of 10 times the hole is plugged in the float bowl. You can soak them all you want. Use ultrasonics and seafoam but they will not clear up. Use a single strand of SS wire from a cable and work at it until contact cleaner sprays through it. The punchout holes in the gskets need removed from the choke holes also. If it still won't start cold it has tight valves and low compression.
      K&L carb cleaner wires work if your carefully not to break them.
        • 5061
        Take a look at this diagram. Mechanically, I don't know what the heck it actually does, but see "vent to bowl at mating surface":
        • pggg
          • 1609
          • NZ
          #34
          From what I can figure, the 10 o'clock inlet breather hole flows air to the tiny pinhole in the thin choke tube that acts as a breather to allow the starter circuit to flow the fuel. Same principle as the fuel tank breather.
          • petejw
            • 2269
            • sydney australia
            #35
            That is one of the best pics ive
            seen 4 the workings of these
            carbies, ive had mine off so many times in the past cpl
            of weeks ive lost count.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            1981 xs1100 RH (aus) (5N5)
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
              • 5061
              #36
              That makes sense!
                • 5061
                #37
                Thanks! I originally made the schematic for myself because I didn't want to have to blow air into all of the orifaces the NEXT time I went through the carbs again.
                • prometheus578
                  XS-XJ Super Guru (RESIGNED)
                  • Aug 2004
                  • 4012
                  • Olympia , Wa.
                  #38
                  Whilst you're out doin' your Cricksness Chopping next week, stop by a music store and pick up a pressinck for thyself. Get the three smallest sized diameter guitar strings; great for cleanin' carb passages. (Saw that tip on here somewhere) They're about 75 cents apiece.
                  • xs650mike
                    • 1286
                    • Lake County, California
                    #39
                    When you cut off those guitar strings into handy lengths don't forget to dress the ends with a jeweler's file so you don't have sharp edges to slice up those passages in your carb bodies and jets. Guitar strings are tempered steel!
                    Shiny side up,
                    650 Mike
                    XS1100SF "Rusty", runs great, 96k miles
                    XS650SJ "The Black Bike", engine from XS650H with 750cc big bore kit, 30k miles
                    Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid in broadside, thoroughly used up, worn out and defiantly shouting, "WOW, what a ride !" - [URL="http://www.flyingsnail.com/Sprung/index.html"]Sprung[/URL]
                    • GNEPIG
                      • Apr 2005
                      • 1656
                      • fl
                      #40
                      .. ok, not that i like busting anyones stones or anything (except on 650 mike, i think he likes that) but in the first pics you see by the wire pulled through it that the 10 oclock hole just like the hole opposit of it is just a carb vent, i'm not real sure but i think these holes pull a vacuum on the float bowls to help bring the fuel down from the gas tank just like the vent hoses on the earlier
                      model carbs
                      .. from what we can tell from the next two pics the wire goes from that transfer passage on top of the float bowl to the top of the float chamber above the fuel level pointing towards the vent at 10 oclock. what this tells me is this passage helps draw fuel up the straw (puts a vacuum no the little hole at the top of the straw thats in line with the transfer passage) for the choke to use when there is not quite enough vacuum in the ventury to do the job, like on a cold start up.
                        • 5061
                        #41
                        Yeah, that is different than the earlier carbs. I believe the gasket must be punched to allow air into the enrichener tube with either carb type.
                        model carbs
                        • xs650mike
                          • 1286
                          #42
                          .. ok, not that i like busting anyones stones or anything (except on 650 mike, i think he likes that) but in the first pics you see by the wire pulled through it that the 10 oclock hole just like the hole opposit of it is just a carb vent, i'm not real sure but i think these holes pull a vacuum on the float bowls to help bring the fuel down from the gas tank just like the vent hoses on the earlier model carbs...
                          I notice you're using a string wrapped with nickel wire there, that'll clean things well and safely.
                          Shiny side up,
                          650 Mike
                          • GNEPIG
                            • Apr 2005
                            • 1656
                            • fl
                            #43
                            .. its the spring from the inside lip of an old wheel seal, fork seal, shift shaft seal something like that, i work at a cycle shop, these are free to me all day long
                            • xs650mike
                              • 1286
                              #44
                              Oh.
                              Shiny side up,
                              650 Mike
                              • pggg
                                • 1609
                                • NZ
                                #45
                                Here's that breather circuit on the early type carbs.
