T.C. those figures of mine are from comparing my 12T against my 17T(XS650). I should have said centre to edge, not diameter. My goof. The distance to edge difference between 12T and 17T is 13mm. Which will make the difference between 13T and 14T as 4.3mm? I'm thinking that's correct?
Yeah, I went thru all the sprocket books at the local bike shop at the start, and the range is bewildering to say the least! The best I could find was the good old XS650 with a 17 as smallest available(530). Still too big for clearance. Jim from Aussie says the TZ750 has the same pattern also, but if it comes as a 14T, I don't know, but I very much doubt it. BUT maybe there's a chance it does. A 530 pitch sprocket will fit the spline without needing a collar, but the rear wheel/sprocket will need to come as 530 as standard. My Kawasaki wheel came as 525 as standard, but 520 was available in conversion sprockets.
How much was the one they made for you, and how much does it weigh? Might have to place an order with them THRU you, and have you ship US some, at least for Chevy and Me!!
Here's a downloadable sprocket catalogue, it's not the special pattern/dimension type the bikeshops have, but it's quite helpful on these sorts of things.
And after seeing this picture, the TZ750 used the 17T sprocket but can't/couldn't find a listing for it for the spline patter?
So...even with shipping, it might still come out much cheaper ordering them from your source than here!?
