Hey Patrick
That thing looks good! Have you decided on a name for it yet? How about "Frankencycle"?
!! Had me wondering if the fabricated swingarm would work! PHEW!! I merged this new thread with the old one for continuity, so people could follow it ALL, and YES, I'm sure MANY people are following it with baited breath!
The ride report is all positive for handling and performance. I did think that maybe the lighter rear end and radial rear/ ply front mix could possibly upset some sort of balance or weight distribution or something, but handling has improved for some reason. It just feels better in corners and is rock solid at speed.
Looks awesome though!
If the front sprocket is positioned more to the right, there's no problem with clearance. BUT the only way to move the front sprocket more to the right, is to machine more metal off the hardened spline.
Even then, you'll only gain a few mm's before running out of metal to grind off. So basically, you're stuck with only a very small gap for the chain to run through unimpeded to the rear sprocket.
