Who Uses Synthetic
  • clcorbin
    • Jan 2010
    • 495
    • Albuquerque, NM
    #136
    I've been using Mobile 1 pretty much from day one, 22 years. I DID change to dino oil on this last oil change as some folks have suggested that it would help with the slipping starter clutch. The starter has been acting the same way for the 22 years I have owned the bike, so I have no idea if the Mobile 1 oil has contributed to the problem or not.
    I have not had any issues with my bike's clutch that I am aware of. We shall see if I notice any difference.
    -- Clint
    • ross
      • Dec 2006
      • 542
      • see signature...
      #137
      what happens in camp "rebel devil"....
      hey there folks....seems like quite the to do about oil around these parts.....i was thinking about using the oil these guys found.....
      (for gods sake their all wearing white!!)
      but then came to my senses and have been using this every time since i became owner....
      change every 2000 miles and filter also....no exceptions....runs smooth and strong.....anywho, if it fubar's, can take it back to yamaha and ask them what kind of discount their gonna give me on a new one.......(XS that is!)
      and that, folks, is just my .02 cents.....ride hard, ride safe....ross
      rebel devil
      1979 xs 1100f standard
      authenic historical vehicle
      42°36'23.52"N, 82°52'44.78"W
      "I'M IN MY HAPPY PLACE"
      "i got 14 jobs mon....you only got 1 job....you lazy bones mon"
      "if you don't wrench on it, get behind me satan!"
      '96 venture cct.....installed!
      stainless, braided, pvc coated brake lines
      i can translate...deustch, nederlands, 汉语, 漢語, français, ελληνικά, italiano, 한국어, português, русско, español and most importantly, 日本語....
      • cycle builder
        • 6
        • Red Deer Alberta Canada
        #138
        cycle builder
        I have used Castrol Syntech 5- 50 in my motorcycles for as long as Syntech has been out and find the engines to be much quieter and run a lot cooler than with non synthetic oils. Used Shell Rotella T in one motorcycle years ago and had pistons collapse several times. Switched to Castrol and problem stopped just like that. Have never had clutch slippage and my XS1100 is bored to 1200 which increases the horse power by quite a bit.
        • HOJO
          • Jun 2009
          • 6
          • Rocky Mount, NC
          #139
          Started using Castrol 20-50 about 6 months ago. Haven't ridden much because of the weather. Rode a couple of hundred miles this weekend and had to add oil 2 times. Has anybody else had similar problems?
          HOJO
          1982 XJ1100
          • CatatonicBug
            • 6117
            • Clinton, UT
            #140
            You had to add oil twice in 200 miles?? Sounds like you've got a huge oil leak somewhere. Do you notice oil dripping out anywhere when parked? Are you checking the oil level while the bike is on the centerstand, or the sidestand?? If the sidestand, you have massively overfilled the oil, and it's probably being pushed out the vent holes.
            • DenyP
              • 599
              • Staples, Minnesota 56479
              #141
              Definitely not the fault of the oil! Have had great luck with Castrol 20-50.
              Deny
              • snowdog51
                • May 2006
                • 348
                • st. paul ,mn
                #142
                oil
                amsoil motorcycle oil the best use it then you don't have to think about oil
                just my opion bill
                bill hane
                • Axel
                  • May 2007
                  • 869
                  • Renfrew,Ontario
                  #143
                  Amen to that .Just put Amsoil Severe Gear 75w90 in my drives as well .
                  XJ1100K
                  Avon rubber
                  MikesXS black coils
                  Iridium plugs w/ 1k caps
                  MikesXS front master
                  Loud Horns (Stebel/Fiamm)
                  Progressive fork springs
                  CIBIE headlight reflector
                  YICS Eliminator
                  • snowdog51
                    • May 2006
                    • 348
                    • st. paul ,mn
                    #144
                    amsoil
                    man i forgot to say amsoil 10 w synthetic forkoil is killer in 40years as wrench there's nothing even close you put it in a fork it's just unreal
                    bill
                    bill hane
                    • Ivan
                      • Jul 2008
                      • 2524
                      • Hutchinson KS
                      #145
                      In grammar class we learn of things like prefixes, suffixes and root words. Well, the root word in amsoil is soil. Which is what it is. Its just regular oil with lots of hype added, which is where the soil part comes in. I bet I have replaced 30 engines in my life due to the BS that amSOIL reps spew. "You never have to cange the oil, just the filter" or "You only have to change the oil every 25 thousand miles." Total crap. They say that but don't have any answers when the bearings and crank looks like someone threw sand in the motor. Try getting amSOIL to pay for an engine that obviously died because their oil went tits up and left the engine spinning on acidified soot and sludge, and they laugh at you saying they have no liability in the matter. When the rings are so worn out the compression won't even register on a gauge, they say its the airfilter's fault.
                      I have no doubt its quality oil, but it doesn't live up to all the lies they propagate. If you change it on time, its probably just as good as any other oil out there, but it isn't superman.
                      What do I use? Anything that's cheap and isn't in a pennsoil (root word again) bottle. So far the parts stores have been carrying Castrol or valvolene MC oil at the same prices as their normal oil, so I use it.
                      Ich habe dich nicht gefragt.
                      • snowdog51
                        • May 2006
                        • 348
                        • st. paul ,mn
                        #146
                        amsoil
                        it never occured to me not to change it every 2000 miles if amsoil sez change every 20,000 they are crazey you and i agree pensoil is sh t
                        bill hane
