cam chain tensioner
  • DeanR
    • Jan 2005
    • 1499
    • Finger Lakes NY
    cam chain tensioner
    Just measured depth inside the tensioner hole after removing the plug - 12mm - does this sound ok? A past thread said 20mm means no more adjustment available and 14.6mm would be for a properly adjusted new chain. There was some oil behind the plug. Would this indicate needing to check any further for a leak?
    Also, does it matter if you do the adjustment before or after checking the valves? Thanks everyone.
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
  • randy
    • Dec 2003
    • 4521
    Dean, did you measure after you adjusted the chain?
    • DeanR
      • Jan 2005
      • 1499
      • Finger Lakes NY
      Hi Randy.
      Haven't done anything yet except to pull out the plug to measure
      that depth.
      80 SG
      81 SH in parts
      99 ST1100
      91 ST1100
      • randy
        • Dec 2003
        • 4521
        Okay, so first adjust the chain. Then take a look at the depth. I'll bet you get a big movement
        • DeanR
          • Jan 2005
          • 1499
          • Finger Lakes NY
          Lined up the timing plate mark, loosened the bolt, retightened and it now measures 17mm, even though I didn't hear anything move or shift.
          80 SG
          81 SH in parts
          99 ST1100
          91 ST1100
          • DeanR
            • Jan 2005
            • 1499
            • Finger Lakes NY
            Neglected to mention that the timing plate had to be rotated (clockwise) almost the whole way around, maybe aound 320 degrees. Any significance to that?
            80 SG
            81 SH in parts
            99 ST1100
            91 ST1100
            • randy
              • Dec 2003
              • 4521
              No.
