Hello All Ive finally gotton started on my bike and thanx to a few of you guys now have most of the parts i need Thanx to all
However i got started on finishing the clutch up got it all put back together and installed and was about to get started on the Final Drive when i thought well let me go ahead and adjust the clutch as per the manuel, so i installed the new handelbar adjustment thingie, and a new clutch cable (first question i changed my handelbars to a much lower stance and the original cable routing couldnt be obtained so i routed the best i could is it posible this is where im wrong?) ran the cable to the mechanical part and installed it and adjusted there, then adjusted at the handelbar . well when i pulled back on the clutch after all was said and done it pulled Very hard and it failed to go back, so i checked the mechanical housing the spring was pulled as far as it would go but wasnt broke i pushed on the clutch arm it would not go down with out a lot of force
now im not to good with auto mechanics so i could have messed up any where in the adjustment just not sure where
so close and yet so very very far hehe
thanx for the help
thanx for the help
