Hello All Ive finally gotton started on my bike and thanx to a few of you guys now have most of the parts i need Thanx to all
However i got started on finishing the clutch up got it all put back together and installed and was about to get started on the Final Drive when i thought well let me go ahead and adjust the clutch as per the manuel, so i installed the new handelbar adjustment thingie, and a new clutch cable (first question i changed my handelbars to a much lower stance and the original cable routing couldnt be obtained so i routed the best i could is it posible this is where im wrong?) ran the cable to the mechanical part and installed it and adjusted there, then adjusted at the handelbar . well when i pulled back on the clutch after all was said and done it pulled Very hard and it failed to go back, so i checked the mechanical housing the spring was pulled as far as it would go but wasnt broke i pushed on the clutch arm it would not go down with out a lot of force
now im not to good with auto mechanics so i could have messed up any where in the adjustment just not sure where
so close and yet so very very far
hehe
thanx for the help
hehethanx for the help
If it doesn't slide easily, then it got bent, or is cause by something on the frame where you routed it!? Like Randy said, slow sweeping turns, like from the handlebars around the triple tree/yoke area, under the tank, and then down to the right side cover.
