Tranny problems Poll.
    • 7938
    New gears
    Well, I have new gears in hand. Now I just need to fix it!
    vben714, all the info on the fix is here. Just search 2nd gear fix.
      • 7938
      discontinued washer
      I ordered peripheral parts for the tranny fix and just received this reply:
      THIS PART HAS BEEN DISCONTINUED:
      Yamaha WASHER,LOCK for Yamaha 90215-19139-00
      WOULD YOU LIKE TO CONTINUE THE ORDER?
        • 7938
        DUH! I should have checked. It's the same clutch as the XS650. Therefore, Mike's XS has the lock washer.
        • randy
          • Dec 2003
          • 4521
          #124
          That's strange, I just got one from Bikebandit two weeks ago.
          • jjwaller
            • 242
            • Gautier, MS
            #125
            Tranny Again?
            In any case, 30000 miles and no forseeable tranny problems. Yes it clunks worse than the CB750 when shifting into first, but so?
            Now the Carbs on the other hand!
            John
            '81 CB900C ( 10 Speed)
            '78 CB750F ( The F)
            '76 CB400F ( The Elf)
            New '82 Honda MB5 Ring Ding
            Then: '76 CB550K
            '78 CB750F
            '84 VF1100S
            And still Looking!
            • Axel
              • May 2007
              • 869
              • Renfrew,Ontario
              #126
              4th grind
              Mine grinds into 4th but thats it
              XJ1100K
              Avon rubber
              MikesXS black coils
              Iridium plugs w/ 1k caps
              MikesXS front master
              Loud Horns (Stebel/Fiamm)
              Progressive fork springs
              CIBIE headlight reflector
              YICS Eliminator
              • egleaves
                • May 2007
                • 441
                • Sacramento
                #127
                Every once in a while I'll slip out of second into neutral. Other than that, no problems yet.....
                I know this, because Tyler knows this.
                1980 SG
                3J6 003509
                Kerker 4-1 (sans baffles)
                Fuse Block Upgrade
                Mike's XS Green Coils
                Pods w/Homemade Velocity Stacks
                • Cobia
                  • Jul 2007
                  • 1587
                  • Palm Beach County, Fl
                  #128
                  Tranny issues = none
                  Hey TC,
                  My '80 Std only has 19K on it and was at 15K when I bought it.
                  My newly acquired XJ has 31.7K on the clock.
                  Very happy to report neither has tranny issues.
                  1980G Standard, Restored
                  Kerker 4 - 1
                  850 Rear End Mod
                  Automatic CCT
                  1980GH Special, Restored
                  '82 XJ1100 (Sold)
                  • egsols
                    • Jan 2006
                    • 1090
                    • Barrie, Ontario, Canada
                    #129
                    My first 79 had issues at 15k +\- (miles), I think it had been ridden hard. At that time, '89, I was on my own and having just rebuilt a tranny in a Massy tractor figured the xs wouold be no problem. It wasn't, just the price of the new gears.
                    My latest special clunks a little but still feels solid and stays in gear. Has about 25 k miles on it right now.
                    Ernie
                    • DenyP
                      • 599
                      • Staples, Minnesota 56479
                      #130
                      My '78 E will pop out of 1st once in a while if I get on it out of the hole. I had been assuming I didn't get it in all the way. I don't baby the shifting - this just started happening in the last 1000 miles or so.
                      Deny
                      • wa407mpp
                        • Jul 2007
                        • 717
                        #131
                        Probably a stretched clutch cable instead of a trans. problem.
                        Fastmover
                        lion". SHL
                        78 XS1100e
                        • DenyP
                          • 599
                          #132
                          Hey Fastmover, I'll check it out!
                          Thanx
                          Deny
                          • rizzo4u2
                            • 49
                            • hanover,pa.
                            #133
                            79 xs 1100 problems
                            if i dont run the bike for several weeks i have noticed a problem when i , pull it in several times when running and when i attempt to put it in 1st gear and it jumps, like i dont even have the clutch pulled in after several attempts of doing this it finally works it way back to normal, what do you think could cause this problem, i am running mobile 1 syntehtic oil in it, the cable is new and no problems after this occurs when riding
                            mike.s
                            • mixelpix
                              • Sep 2004
                              • 237
                              • Utah
                              #134
                              Hey Rizzo4u2,
                              Lose the synthetic oil, stick to heavy conventionals.
                              I like to use Shells Rotella-T, i think it comes as 15W-40 (?) - but I like it cause it's the closest oil formula available on todays market which resembles the stuff which was available back in the late seventies.
                              Best,
                              -Patrick Kennedy
                              Your Mileage May Vary
                                #135
                                Hey Rizzo,
                                I won't go into oil types, you can read the threads and tech tips and come to your own conclusion.
                                However, aside from the new cable, have you done the adjustment procedure for the engine side cover/clutch lever?? Sounds like it's not set right, and so it's not totally disengaging the plates, so you get the grinding affect!? The procedure is in the tech tips.
