Tranny problems Poll.
  • mro
    • 4276
    • Hayward, California
    #91
    washer
    There is a tech tip about using a washer, but not sure if same as you are talking about.
    mro
    • mason79
      • Mar 2006
      • 1359
      • los angeles, ca
      #92
      okay i put in around 200 miles on the old f and as far a transmission, it does slip out of second gear when i'm going very slow and just cruising it,trice, otherwise no problems with it slipping out wihile speed shifting,
      i don't know much about transmmissions, but i did find a false neutral between 4 and 5 a coupla times, then it would be hard to shift in all gears for a while, until i'm able to get off the freeway and let the rpm's go down a bit and i think that resets some things and the shifting smooths out. maybe i'm wrong here
      i would sure hate to have big tranny problems, i want to spend my time and money beautify it rather that repairing it,
      but show me a 79 anything, that can perform like this for not alot of money,.
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
      • andnew
        • Apr 2006
        • 50
        • Enumclaw, WA
        #93
        My new (to me) XJ shifts like buttah!
        But then again my main ride is a BMW, the finest in outsourced spec built rock boxes, er, transmissions.:-)
        Andy Newell,
        Enumclaw, WA
        03 BMW K1200RSA (Dread Zeppelin)
        1996 Triumph Tiger
        • GNEPIG
          • Apr 2005
          • 1657
          • fl
          #94
          XS Tranny Service Bulletin
          .. while sitting in the garge for the past two days, contimplating a different approach to fixing the first gear problem, i think that i have found it.. not the actual bulletin, but what the bulletin may be about ["i think i have seen the bunnies again George"].. while it is not hard to implicate, it is not real easy either, you still have to remove the shaft and gear cluster.. if your trans is junk already this mod will help after you replace the parts that are bad, but maybe not before.
          .. i will know more about how well it works by the time i make it to WV next week, if i can make it []
          at this moment it is still a money thing, but i have some and the plan is in motion.
          i hope it stops raining up there soon
          .. bump
          • 79XS11F
            • 3563
            • Ottawa, Ont. Canada
            #95
            I don't have any issues with my trany now but wnat to avoid issues in future. I am referring to my back up hop up engine. I think the last owner of this bike harleyed it for lack of a better description.
            Myself I do give 2nd gear a workout on a regular basis because I like to be on the edge of the power band when riding. Given the speed limit on surface streets that means I'm in 2nd gear a lot.
            Rob
            KEEP THE RUBBER SIDE DOWN
            1978 XS1100E Modified
            1978 XS500E
            1979 XS1100F Restored
            1981 Suzuki GS1100
            1983 Suzuki GS750S Katana
            1983 Honda CB900 Custom
            • posthuman
              • 71
              #96
              My XJ100 has 13,000 miles
              Its hard to get it into first unless the RPM is below 1000 when cold, however when the oil warms up, and presumably some metal expands, its fine.
              There is something about viscosity that influences this problem I can't put my finger on...
              The XJ550 I just sold had 55k, it would slip out of second into neutral at the worst moments.
              I tend to try to stay out of second as much as possible, and tend to use 4th more often, to spread the stress over the assembly evenly.
              XJ 1100
              XJ 550
              • randy
                • Dec 2003
                • 4521
                #97
                Try adjusting your clutch
                • MotoMartin
                  • Feb 2007
                  • 26
                  • Oceanside, CA
                  #98
                  Tranny problems
                  My 78 Standard has the first gear problem, but you wouldn't know unless you really accelerated hard in first gear. I have n't had it pop out of gear for a long time because I know it's there and ride around it. It doesn't seem to be getting any worse, as I first noticed the problem many years ago. The bike clunks pretty loudly going into first from neutral but I assume they all do that.
                  1979 XS 1100 Standard (project)
                  1982 Honda CX500 Turbo
                  1995 GSXR750 Streetfighter (project)
                  1978 XS 1100 E (Sold) Owner for 19 years
                    • 8073
                    Mine is just like it. It must be placed in first with "authority".
                    • BIG MIC
                      • Jun 2006
                      • 53
                      • havana,il
                      #100
                      my has been doing really well, i have around 25,000 miles and still shifts like day one ..
                      1982 xj1100j
                      • BIG MIC
                        • Jun 2006
                        • 53
                        • havana,il
                        #101
                        1982 xj1100j
                        • BLUEJEEPLAB
                          • Sep 2005
                          • 703
                          • Miami Valley, Ohio
                          #102
                          Battle Cruiser evidently has had the second gear fix twice. Once by the PO and again this year by me. PO had done the washer reverse on 2nd and it apparently works very well because the dogs on 5th were almost round and still only coming out of second occasionally. After I replaced 2nd and 5th, I left the washer on the reverse.
                          Papa Gino
                          79 and something XS 1100 Special "Battle Cruiser"
                          78 XT 500 "Old Shaky"
                          02 Kawasaki Concours "Connie"
                          • ernie elmore
                            • 40
                            • Irvine, California
                            #103
                            I have had a 80- XS1100G std since new. I got in the habit of "Short Shifting" or skipping 2nd & 4th gears. This worked for 20 years and then shifting degraded. Problem was a bad coil which made the engine run rough. Finally replaced coil and shifts were OK. Sometimes will jump out of 1st or get false nuetral in 2-3 shift. I now shift thru all gears. Keep the engine in proper tune and shifting will be at its best.
                            Ernie Elmore
                            1815 N Tympani Cir
                            Anaheim, CA 92807
                            Ph: 714-340-3173
                            email: xs11ernie-mc@yahoo.com
                            Still Riding at 79 for ....
                            1980 Yamaha XS1100G Std - Everlasting - sold (sob)
                            1983 Yamaha XV920 Virago - Enduring - sold
                            1993 Honda XR650L - Enduro - gave to Son
                            • ernie elmore
                              • 40
                              #104
                              I have a 79 XS1100F Std I bought for a parts bike, but now have a good running bike @ 40 K mi. The bike had the 5th gear blues when I got it, no 5th gear. I replaced the shift drum outside end metal plate w/fingers and missing dowel. About 8K mi later I had poor shifting into 1st with bad noisy neutral, and finally no 5th gear.
                              Problem was bent finger on shift drum metal plate again, which I rebent and fixed.
                              Now 200 mi later, hard shifting into 1st or noisy nuetral. Probably 5th gear will be missing soon.
                              Has anyone had this as a reoccuring problem? What is bending out the finger on the shift drum end plate? Do I need to do a shift pawl alignment? The alignment marks are correct as per the Service Manual.
                              Ernie Elmore
                              1815 N Tympani Cir
                              Anaheim, CA 92807
                              Ph: 714-340-3173
                              • l.arend
                                • Sep 2006
                                • 4
                                • Rockwood Mi
                                #105
                                Tranny
                                My 82 1100 Maxim started at about 50KWould slip out of 1st gear when dropping the hammer.Within 1 1000 milewould slip out of first all the time.Tore down,replaced 1,2,4 and 5 gears ,also one shift fork had wear.Works good
