I also saw the Myth Busters episode on Coca Cola being good for cleaning chrome. A few days later i was out on my bike trying it out and must admit it works pretty good. On the Myth Busters episode, they used aluminum foil also with the coke to polish the chrome. I tried this on two small areas. I learned that if you just rub slightly with the aluminum foil that it helps clean and polish, but I also learned that light pressure is the key because if you apply much pressure to the foil when polishing, it scratches. Its a good thing it was only a small area.
aluminum oxidation tip
I recently tried, turtle wax wheel cleaner, I ve tried different wheel cleaners on my engine, and this seems to work best, they claim, non-acid, using nano-technology. Later 'DogComment
Re: Regarding my tech tip...
Originally posted by 81xsproject
I posted a tech tip about Al oxidation removal with NaOH (lye). I need to mention that the Al should not be soaked in the solution for long periods of time. It does work well to remove oxidation, but if left for long periods it will continue to eat at the Al leaving deep scars and ruin your piece, like it did my grab bar. Any one got an extra?
GeezerHi my name is Tony and I'm a bikeoholic.
The old gray biker ain't what he used to be.Comment
