Building bowl outlet nipple for clear tubing...
  • Shuriken
    • 1093
    • Southwest USA
    Howdy XSives,
    Was there once a thread on how to attach clear tubing to the float bowls to check actual fuel levels? I need to construct some sort of nipple that I can attach clear tubing to. Has anyone else done this? I was thinking perhaps of getting some replacement drain bolts, drilling a hole in them, and soldering some sort of tube to the bolt....
    I am trying to dial in a new set of carbs and want things exact. The carbs are the '79sf models.
    Can someone point me in the right direction?
    Perhaps a vague question here, but with a stock '79sf with 137.5 mains running at 5700ft elevation, what would be a good (leaner) main jet number to start with and does Yamaha still stock them?
    Ben
    1985 Yamaha VMX12n "Max X" - Stock
    Formerly:
    1982 XS650
    1980 XS1100g
    1979 XS1100sf
    1978 XS1100e donor
  • chevy45412001
    • Mar 2003
    • 1412
    • Jacksonville Florida
    main jets
    main jets can be found at any motorcycle shop ,,they average 3-5 dollars a pieace.
    1982 XJ 1100
    • JohnSg
      • Jun 2004
      • 83
      Try Mike's XS for jets
      Here's the link:
      http://www.mikesxs.com/mikesxs-page12.htm
      They are $2.00 each.
      Mike specializes in the XS650, but many of the parts are interchangable with the XS11.
      • Shuriken
        • 1093
        • Southwest USA
        Thanks John.
        Now I just need to find out how to get a fuel nipple setup for the float bowls.
        Formerly:
        1982 XS650
        1980 XS1100g
        1979 XS1100sf
        1978 XS1100e donor
        • Jeremy_Sells
          • 96
          • Portland, OR
          I found that a brake bleeder screw with the right thread pitch and diameter works perfect. I found them at napa for just a couple of bucks each. I can't recall but I think the thread was something like 8x1.25 or something, best to double check. I used a grinder to grind off the tapered part on the end of the threads and the length was just right, doesn't contact the main jet at all. Hope this helps and good luck on the jetting. Finding a dyno and getting a baseline after you set the float heights, timing, valve clearance, etc. will give you a good idea as to where you need to go with the jets. Hope this helps and good luck
          Jeremy
          1979 XS11 Special
          2002 Ducati ST4S
          2012 BMW F800R
          1981 Suzuki GS450E
          1982 Honda XL500R
          • Shuriken
            • 1093
            • Southwest USA
            That sounds like a better idea to me than drilling a bolt and soldering. I guess like you indicate, the trick is getting the right bleeder screw. I'll check into that immediately.
            Ben
            Formerly:
            1982 XS650
            1980 XS1100g
            1979 XS1100sf
            1978 XS1100e donor
            • Bill__Woods
              • 281
              • Circleville, Ohio
              Hello,
              My suggestion would be get a set of float bowls of a 1981 xs1100. They already have the nipple to attach the tube. Someone on the list should have a spare set that they will part with. Otherwise you would need to do some machining on the bowl and install something similar to a brake bleeder screw. Once again, just use the factory 81 float bowls. I believe the 1980 models had the nipple also.
              Good luck.
              Bill Woods
              1981 Yamaha XS1100SH (Eleven Special)
              1985 Kawasuki GS425 Mojave ATV
              2006 Yamaha Wolverine 450 4x4 ATV
              • Shuriken
                • 1093
                • Southwest USA
                Hi Bill,
                I think Jeremy found bleeder screws that fit in place of the float bowl drain screws. The bleeder screws would not be permanent - just temporary.
                If someone had spare bowls with the nipple outlets I would certainly try to go that way. Otherwise I'll try to just use the bleeder screws method without machining the bowls themselves.
                Ben
                Formerly:
                1982 XS650
                1980 XS1100g
                1979 XS1100sf
                1978 XS1100e donor
                • Jeremy_Sells
                  • 96
                  • Portland, OR
                  You're right, the bleed screws are just temporary to set the height and then replace with the drain screws and you're good to go. BTW, it has been my experience that the float bowls with the drain tube built in do not fit the earlier carbs, I have both styles laying around and that is why I had to go with the bleed screws. The early and late float bowls mount the same and share similar deminsions but the little pick up tube that is in the carb body and extends down into the bowl is located in different places on the early and late carbs. Hope this helps.
                  Jeremy
                  1979 XS11 Special
                  2002 Ducati ST4S
                  2012 BMW F800R
                  1981 Suzuki GS450E
                  1982 Honda XL500R
                  • Bill__Woods
                    • 281
                    • Circleville, Ohio
                    oops, my bad. I thought they were interchangeable.
                    Bill Woods
