Mac exhaust 4 into 2 -Sidestand Stop
    • 7863
    My sidestand now stops on the centerstand bolt. What is the easy solution to a stop. I'd like to install a Mac 4 into 2 that I have. I'd prefer not dent the pipe with the sidestand.
    • 2053
    I suggest a rubber collar on the 'prong' that your foot touches to actuate the sidestand. The rubber rests on the exhaust....making a cushion when it stops against the exhaust and preventing any rattles or scratches while you are riding.
    Surprisingly, there is no problem melting or cooking the rubber.
    That's what I am using on the XS750 and Venturer.
    I know it's a standard part for the XS750 Special, but I don't about the other models.
    I used a shock absorber bushing on the Venturer because it what I found in my spare parts.
    It's hard to predict the geometry of the MAC vs the OEM, but the rubber can be slid to a sweet spot to function properly.
    I can take a picture tomorrow if it helps.
      • 7863
      No, I get it. Thanks. That’s likely the simplest solution.
        • 5061
        I have a bike (78 with 81H pipes) where I have to install the centerstand for maintenance purposes because it will not retract. It is easy on/off.
          • 7863
          I have no centerstand issue. It's mounted and has a stop. If it fails to clear the exhaust, I see how to fix it. My issue is the kick stand and I believe Mike has offered the solution.
            • 2053
            I misspoke. The Venturer has a bumper built into the Special exhaust.
            The XS750 has the rubber collar.
            It's also the XS1100SG ("Bagger") I was thinking about. I installed the Jardine spaghetti on it a few weeks ago, and had the same issue that you anticipate. Here is the shock absorber bushing I used:
            It's nifty the bushing has an hourglass shape to follow the cross-sectional shape of the exhaust.
            Since shock absorbers come as a pair, I must have a matching bushing in my stash. PM an address if you want it.
              • 9980
              If you ever looked at Ol' Okie you would see that I extended the foot bar about 3 inches because I couldn't catch it with my foot to put it down. I slid a piece of rubber heater hose over it to protect the Mac muffler. I did the same with the center stand foot bar but had to split the hose and wrap it with wire to keep it on there.
                • 7863
                Originally posted by BA80
                If you ever looked at Ol' Okie you would see....
                Now, why would I ever look at Ol' Okie? ;-)
                  • 2053
                  Marty:
                  Your mailbox has exceeded the allowable storage capacity.
                  I sent the rubber stopper for your kickstand on 8/17/20.
                  I see it hasn't been delivered yet.
                  I wanted to send the tracking number so I can throw away the receipt.
                  The tracking number is:
                  9500113748210230072816
                  -Mike A.
                    • 7863
                    Marty:
                    -Mike A.
                    Thank you, Mike!
                    I emptied my private messages several days ago. I'll revisit that. Maybe it got caught up in the transition.
