Mac exhaust 4 into 2 -Sidestand Stop
    My sidestand now stops on the centerstand bolt. What is the easy solution to a stop. I'd like to install a Mac 4 into 2 that I have. I'd prefer not dent the pipe with the sidestand.
    I suggest a rubber collar on the 'prong' that your foot touches to actuate the sidestand. The rubber rests on the exhaust....making a cushion when it stops against the exhaust and preventing any rattles or scratches while you are riding.
    Surprisingly, there is no problem melting or cooking the rubber.
    That's what I am using on the XS750 and Venturer.
    I know it's a standard part for the XS750 Special, but I don't about the other models.
    I used a shock absorber bushing on the Venturer because it what I found in my spare parts.
    It's hard to predict the geometry of the MAC vs the OEM, but the rubber can be slid to a sweet spot to function properly.
    I can take a picture tomorrow if it helps.
      No, I get it. Thanks. That’s likely the simplest solution.
        I have a bike (78 with 81H pipes) where I have to install the centerstand for maintenance purposes because it will not retract. It is easy on/off.
          I have no centerstand issue. It's mounted and has a stop. If it fails to clear the exhaust, I see how to fix it. My issue is the kick stand and I believe Mike has offered the solution.
            I misspoke. The Venturer has a bumper built into the Special exhaust.
            The XS750 has the rubber collar.
            It's also the XS1100SG ("Bagger") I was thinking about. I installed the Jardine spaghetti on it a few weeks ago, and had the same issue that you anticipate. Here is the shock absorber bushing I used:
            It's nifty the bushing has an hourglass shape to follow the cross-sectional shape of the exhaust.
            Since shock absorbers come as a pair, I must have a matching bushing in my stash. PM an address if you want it.
              If you ever looked at Ol' Okie you would see that I extended the foot bar about 3 inches because I couldn't catch it with my foot to put it down. I slid a piece of rubber heater hose over it to protect the Mac muffler. I did the same with the center stand foot bar but had to split the hose and wrap it with wire to keep it on there.
                Originally posted by BA80
                If you ever looked at Ol' Okie you would see....
                Now, why would I ever look at Ol' Okie? ;-)
                  Marty:
                  Your mailbox has exceeded the allowable storage capacity.
                  I sent the rubber stopper for your kickstand on 8/17/20.
                  I see it hasn't been delivered yet.
                  I wanted to send the tracking number so I can throw away the receipt.
                  The tracking number is:
                  9500113748210230072816
                  -Mike A.
                    Marty:
                    -Mike A.
                    Thank you, Mike!
                    I emptied my private messages several days ago. I'll revisit that. Maybe it got caught up in the transition.
