front fork assy upgrade
  • mxmikie
    • Aug 2008
    • 482
    • Bouse az
    has anybody done this yet ? https://cognitomoto.com/collections/...17737416114291
    careful what you wish for.........you might get it
    • 2072
    No but just spent an hour perusing their site.
    Their products look to be first class and have opened up some ideas on future builds.
    Thanxs for the link
    • mxmikie
      • Aug 2008
      • 482
      • Bouse az
      funny i just happen to have a gsxr750 lying around with nothing to do........we shall see
      • Tobiczyk
        • May 2016
        • 50
        • Royal Oak, MI
        I have done the busa swap and i can say it is clearly the easiest there is. Simple bearing change and drops right in. Fantastic. No stem changes or anything.
        81 "Cafe" Build
        80 MNS
        81 MNS
        • mxmikie
          • Aug 2008
          • 482
          • Bouse az
          what year what bearings ?
          • Tobiczyk
            • May 2016
            • 50
            • Royal Oak, MI
            99-07 are all the same. I used all parts from 07. all balls racing has a drop in kit for the busa.
            there is your top and bottom bearing. remove the original races in the frame and drop these in. I did all of mine on an SG but it believe its practically the same for any year/model.
            Now you will get a bit of drop since the hayabusa front end is significantly shorter but not bottoming out. just keep in mind that you might need to modify the kick stand to keep it from being too upright and center stand is probably going to be next to impossible to use.
            81 "Cafe" Build
            80 MNS
            81 MNS
            • mxmikie
              • Aug 2008
              • 482
              • Bouse az
              how long are the hayabusa forks unloaded ?
              • mxmikie
                • Aug 2008
                • 482
                • Bouse az
                i found it looks like 3 inches shorter https://ariesmotorcycles.com/sport-bike-fork-lengths/
                • mxmikie
                  • Aug 2008
                  • 482
                  • Bouse az
                  do you have pictures of your bike before and after the front end swap ?
                  • Tobiczyk
                    • May 2016
                    • 50
                    • Royal Oak, MI
                    I'm still in the process of building. I bought a basket case trio and am extremely slowly combining them into a single bike. Unfortunately that means no completed pictures.
                    If you search for xschop he did the same swap years ago. There are posts of his bike
                    81 "Cafe" Build
                    80 MNS
                    81 MNS
                    • alaskey2
                      • Apr 2014
                      • 271
                      • 60940
                      Why would you do this? What is the benefit?
                      78 E
                      • Tobiczyk
                        • May 2016
                        • 50
                        • Royal Oak, MI
                        I cant speak for anyone else but I had multiple reasons for it.
                        1. better suspension. Having a newer set of larger inverted forks compared to the original forks on the XS.
                        2. better brakes. We all know the brakes are ok but having much better brakes is never a bad thing.
                        3. easy swap. The hayabusa front end is a single bearing change swap. practically drops right in. There is no amount of money/time you can spend on the original front end to get the same ease of use, performance, tunability, etc than you can get from the swap. Just cant be beat.
                        4. looks. I wanted to drop the front end down a bit and this also handles that.
                        Overall there were no real reasons for me to keep the original forks on there since I was already dealing with a pile of parts to begin with. If I were dealing with a much nicer bike and wanted to keep it original then i might have spent the time and money on refurbishing and building everything stock. Since I wasn't, i decided to make it the bike i want it to be
                        81 "Cafe" Build
                        80 MNS
                        81 MNS
                        • alaskey2
                          • Apr 2014
                          • 271
                          • 60940
                          Thanks for answering. The ease of upkeep sounds like a HUGE benefit.
                          78 E
                          • Bergman16
                            • Jun 2014
                            • 286
                            • New York, N.Y.
                            Thanks for the info. I’d be very interested in hearing about how hard it is to deal with the stand(s) after. I’m that guy who worries probably too much about the thing tipping over all the time so use the center stand a lot.
                            Steve R
                            '80 SG
                            "Fred" -- TC fuse box, stock airbox/exhaust/jets, SS brake lines, Windjammer V fairing, Cibie headlight lens, TKAT fork brace, Showa rear shocks, MikesXS emulators
                            Former bikes:
                            1973 Yamaha 125 Enduro (brother's but I 'borrowed' it a lot, usually after midnight)
                            1978 XS400E Red
                            1981 XS850 Special (Stingo)
                              • 1951
                              I'm with you. I'm not sure I even need a kickstand.
