has anybody done this yet ? https://cognitomoto.com/collections/...17737416114291
front fork assy upgrade
No but just spent an hour perusing their site.
Their products look to be first class and have opened up some ideas on future builds.
Thanxs for the link1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors )
99-07 are all the same. I used all parts from 07. all balls racing has a drop in kit for the busa.
https://www.allballsracing.com/forkconversion
https://www.allballsracing.com/99-3540-5.html
https://www.allballsracing.com/99-3519-5.html
there is your top and bottom bearing. remove the original races in the frame and drop these in. I did all of mine on an SG but it believe its practically the same for any year/model.
Now you will get a bit of drop since the hayabusa front end is significantly shorter but not bottoming out. just keep in mind that you might need to modify the kick stand to keep it from being too upright and center stand is probably going to be next to impossible to use.81 "Cafe" Build
80 MNS
81 MNS
Originally posted by Tobiczyk View Post99-07 are all the same. I used all parts from 07. all balls racing has a drop in kit for the busa.
Now you will get a bit of drop since the hayabusa front end is significantly shorter but not bottoming out. just keep in mind that you might need to modify the kick stand to keep it from being too upright and center stand is probably going to be next to impossible to use.careful what you wish for.........you might get it
i found it looks like 3 inches shorter https://ariesmotorcycles.com/sport-bike-fork-lengths/careful what you wish for.........you might get it
I'm still in the process of building. I bought a basket case trio and am extremely slowly combining them into a single bike. Unfortunately that means no completed pictures.
If you search for xschop he did the same swap years ago. There are posts of his bike81 "Cafe" Build
80 MNS
81 MNS
I cant speak for anyone else but I had multiple reasons for it.
1. better suspension. Having a newer set of larger inverted forks compared to the original forks on the XS.
2. better brakes. We all know the brakes are ok but having much better brakes is never a bad thing.
3. easy swap. The hayabusa front end is a single bearing change swap. practically drops right in. There is no amount of money/time you can spend on the original front end to get the same ease of use, performance, tunability, etc than you can get from the swap. Just cant be beat.
4. looks. I wanted to drop the front end down a bit and this also handles that.
Overall there were no real reasons for me to keep the original forks on there since I was already dealing with a pile of parts to begin with. If I were dealing with a much nicer bike and wanted to keep it original then i might have spent the time and money on refurbishing and building everything stock. Since I wasn't, i decided to make it the bike i want it to be81 "Cafe" Build
80 MNS
81 MNS
Thanks for the info. I’d be very interested in hearing about how hard it is to deal with the stand(s) after. I’m that guy who worries probably too much about the thing tipping over all the time so use the center stand a lot.Steve R
'80 SG
"Fred" -- TC fuse box, stock airbox/exhaust/jets, SS brake lines, Windjammer V fairing, Cibie headlight lens, TKAT fork brace, Showa rear shocks, MikesXS emulators
Former bikes:
1973 Yamaha 125 Enduro (brother's but I 'borrowed' it a lot, usually after midnight)
1978 XS400E Red
1981 XS850 Special (Stingo)
Originally posted by Bergman16 View PostI’m that guy who worries probably too much about the thing tipping over all the time so use the center stand a lot.-Mike
