...Has anyone replaced theirs? I'm just wondering what the process is and how many cuss words are involved. '81 XS1100LH. I'm guessing that you just cut the old ones off and drive the new ones on, but since I don't actually know, and REALLY don't want to screw it up, I thought I'd ask. Any info (or links) y'all can provide would be most appreciated. I've done a forum search, to no avail. TIA.
Front Foot Rest Rubbers...
-Jon-
1981 XS1100LH MNS #103 ("Dark Side")
Yamaha "Mini Cruiser" Windscreen, K & N filters, Iridium Plugs, ATK Fork Brace, LED T.S. Conversion, Bridgestone S11 Spitfires.
Otherwise all original, definitely a Survivor.
Previous:
1981 XS850LH MNS (R.I.P. 1983), 1982 XJ650 SECA TURBO, 1983 XJ650 SECA TURBO
Cage:
2K2 TB
"Light travels faster than sound. That is why some people appear bright, until you hear them speak."Tags: None -
If you have new ones in hand, and the old ones are trash, just cut them off. They're hooked bottom inboard if you want to try to save them. The new ones just slide on.Marty (in Mississippi)
XS650E -
-Jon-
Previous:
Cage:
2K2 TB
"Light travels faster than sound. That is why some people appear bright, until you hear them speak."Comment
Your challenge is to find the flat ones for your pegs. I believe the XJ used the same ones so maybe use that in your search. Wait until you have new ones in hand before removing old ones.
Phil1981 XS1100 H Venturer ( Addie)
2004 Kawasaki Concours. ( Black Bear)Comment
foot pegs
I can supply 4 complete foot pegs with mounts. Rubber parts are not tired or worn, used stock parts off standard model. $50 shipped by us priority mail, have two sets like this, send me a pm thanx andreasComment
I got some front foot peg rubbers for my XS11SG from sumo rubber in the UK.
They fit perfectSlow down and enjoy life. If you are in that much of a hurry, you should have left eariler.
Current rides:
80 XS1100SG
82 JX1100
83 Venture Royale
86 V-MaxComment
Whoa, there is a lot of hard to find parts available from that place.....like the condom that goes over the brake master cylinder plunger. I always tear that thing trying to get it off and have to buy a $25 rebuild kit just to get the condom.I got some front foot peg rubbers for my XS11SG from sumo rubber in the UK.
They fit perfect
Thanks for posting it Mark!-Mike
Previous: '68 Motoguzzi 600cc + '79 XS750SF 22k miles +'84 Honda V65Comment
Current rides:
80 XS1100SG
82 JX1100
83 Venture Royale
86 V-MaxComment
More great parts!
I see lots of great deals on other 'hard to find' part on that CruisinImage site.
Kurt bought a set of piston rings from CruzinImage and he seemed pleased with them.
I might start replacing brake caliper parts now I can see them for $10/set! Usually they are about $25/caliper.
Who would think you could get a carb slide piston (with diaphram) for $20?
I would expect to pay $100.-Mike
Posts like this are why it is essential we get this site back up and running properly. Well done mlew for finding and sharing some excellent sources of hard to find parts.
Note the Sumo rubber parts are priced in Euro. Look for the Euro amount for free shipping to USA. Landed cost may be cheaper to buy 2 or add some other parts to your order.
To You All..
...Just wanted to say THANK YOU to you all for your replies. It's good to know there are people still around willing to share of themselves to help other folks. I very much appreciate it. Y'all have a good evening.
-Jon-
Previous:
Cage:
2K2 TB
I noticed that sumo rubber has them listed as the original 3H5- part number. Do you know if yours have the steel plate in them, or are they solid rubber? I found some repros on fleaBay, which they describe as solid rubber. I found some 4X7's also, but I think the 4X7's don't have the angle on the underside on the outer end. Thanks.I got some front foot peg rubbers for my XS11SG from sumo rubber in the UK.
They fit perfect
-Jon-
Previous:
Cage:
2K2 TB
I can not tell by scrutinizing mine whether or not there is steel in them. I know there is in my XS650 covers and they're the same as the earlier XS1100. If mlew says they fit perfect, I think you can take that to the bank. I'd go with him on that.I noticed that sumo rubber has them listed as the original 3H5- part number. Do you know if yours have the steel plate in them, or are they solid rubber? I found some repros on fleaBay, which they describe as solid rubber. I found some 4X7's also, but I think the 4X7's don't have the angle on the underside on the outer end. Thanks.Marty (in Mississippi)
XS650EComment
Indeed..there is still a viable XS1100 community..This site is sorely in need of an upgrade...in ownership as well...Posts like this are why it is essential we get this site back up and running properly. Well done mlew for finding and sharing some excellent sources of hard to find parts.
2005 Honda SilverWing 600
2018 Honda PC-Xpress 150Comment
The original had a metal plate on the outside underneath on the outer angle. I don't think the plate is structural but there in case you scrape the peg on the road. The new ones did not have them, but they look and fit exactly as the OEM. No Yamaha logo on it either. I have had them on for a year and they have not come loose or given me any problems or concerns. You cant tell a difference unless you look under the peg and know what you are looking for.I noticed that sumo rubber has them listed as the original 3H5- part number. Do you know if yours have the steel plate in them, or are they solid rubber? I found some repros on fleaBay, which they describe as solid rubber. I found some 4X7's also, but I think the 4X7's don't have the angle on the underside on the outer end. Thanks.Last edited by mlew; 11-23-2019, 10:46 PM.Slow down and enjoy life. If you are in that much of a hurry, you should have left eariler.
Current rides:
80 XS1100SG
82 JX1100
83 Venture Royale
86 V-MaxComment
