Yamaha service manual omission
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    I looked through the Yamaha XS1100 factory service manual and can't find the amount of gear lube that goes into the final drive.
    I suspect it's something like the middle drive, 4.4 oz. when filling after complete draining, 3.5 or 3.3 oz. when just changing, odd ?
    Nowhere can I find the number of ounces for the final drive, changing, complete filling when drained.
    Just interested.
    Can anyone answer please ?
    T.I.A. Done
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
  • BillyRok
    • Aug 2011
    • 421
    • Shortsville, NY.
    I have both an XJ and Xs manual. They agree that the final drive holds 0.32 US quarts but the middle drive amounts differ: 0.396 qts for the XJ and 0.38 qts for the XS although I'm not sure that's a measurable difference. I always go to the full line on the factory dipstick.
    Billy
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      Thank You Billy ! I have the Mechanics factory manual, I find the engine and middle gear oil amounts but not the final drive. If it's in there would you be willing to tell me what page in the XS manual ?
      I have the SH, H and LH with supplements.
      76 XS650 C ROADSTER
      80 XS 1100 SG
      • CaptonZap
        • Jun 2010
        • 1748
        • Denver
        Page 2-11 of the Genuine Yamaha XJ 1100J manual, it says;
        Final gear case: Approx. 0.30 L (0.26 Imp qt, 0.32 US qt)
        I fill it to the bottom of the filler hole threads and call it good.
        CZ
        • donebysunday
          • Oct 2012
          • 1737
          • New Berlin, Wi.
          CZ
          CZ, Thanks !
          That seems very full ?
          Maybe cut down on (what do they call it?) frothing, foaming, aerating ?
          Do you do the same with the middle gear unit ?
          Did Yamaha leave this measurement out of the XS1100 manual ?
          76 XS650 C ROADSTER
          80 XS 1100 SG
            CZ
            In Yamaha Manual 1st edition XS1100 same information on page 2-13
            Oil will blow out of the top if you overfill.
            Use the dip stick provided in tool kit......40 + years ago
            Dip stick was still available from Yamaha.....10 years ago.
            I like CZ fill to threads for final drive.
            Always remove filler cap before removing drain cap.
              • 8931
              Don't fill the middle drive up to the threads, there will be waaay too much in there.
              • MPittma100
                • Aug 2011
                • 2359
                Yamaha Manual
                Stick to the book.
                1981 XS1100H Venturer
                K&N Air Filter
                ACCT
                Custom Paint by Deitz
                Geezer Rectifier/Regulator
                Stebel Nautilus Horn
                EBC Front Rotors
                Limie Accent Moves On In 2015
                Mike
                • donebysunday
                  • Oct 2012
                  • 1737
                  • New Berlin, Wi.
                  Haynes/Clymers
                  Thank You All !
                  Maybe Haynes/Clymers had the amount listed for the final drive, I used to have all three.
                  Still the measuring tool will work.
                  76 XS650 C ROADSTER
                  80 XS 1100 SG
                  • CaptonZap
                    • Jun 2010
                    • 1748
                    • Denver
                    Quoting from the same source;
                    Middle gear case: Approx. 0.375 L
                    (0.33 Imp qt, 0.396US qt)
                    Recommended oil: SAE 80 API Hypoid gear oil.
                    SAE 80W90 may be used for all conditions
                    GL-4, GL-5, GL-6 ratings are all approved.
                    Yamaha doesn't always present information in the places we would expect.
                    It is probably in there, just not where you would first look.
                    CZ
                      I would HIGHLY recommend using 75-140w synthetic oils in both middle drive and final drive as opposed to the old school recommended oils. I found years ago that the 75-140w syn. reduced final drive temps. by 15 degrees after riding an interstate testing some 150miles@ a constant 80mph. Testing both choices for same distance,G.Junction, Colo. to Green River, Utah. Royal Purple was and is my syn. choice. Do NOT use same weight choice for synthetic! 80-90w synthetic oil does NOT have the same cling factor nor 'pound out' factor using equivalent conventional choices! If using 80-90w syn., it WILL cause an early demise of final drive bearings! Remember, heat IS equal to friction!
                      • Tom Andersen
                        • Aug 2003
                        • 75
                        • Pueblo, Colorado
                        make your own
                        https://www.xs11.com/xs11-info/tech-...-dipstick.html
                        1982 XJ650RJ Seca
                        2001 Yamaha XT225
                        2002 Suzuki DR650
                        2008 Suzuki DL650 VStrom
                        AMA charter life member
                        • donebysunday
                          • Oct 2012
                          • 1737
                          • New Berlin, Wi.
                          Dip stick
                          is no longer available though I just found one on ebay for 18 dollars.
                          I guess in the past I just added then checked with the dipstick, added/checked then again until I got it right, or as was said it's in the book somewhere ?
                          76 XS650 C ROADSTER
                          80 XS 1100 SG
                          • MarkD
                            • Jun 2013
                            • 488
                            • N. Michigan
                            Done, I did the same this fall, add the lube and check with the dipstick that was in my original tool kit. I made sure the bike was on the level and standing straight.
                            79 F
                            1967 Suzuki X6 Hustler
                            1973 Suzuki TM 125
                            1979 XS1100 F
                            2005 Kaw. Vulcan VN800
                            1991 BMW K75
                            • webbcraft2150
                              • Sep 2002
                              • 1605
                              • AUSTIN.TX
                              There was drawing posted here somewhere with dimensions. I made a couple out of scrap plastic.
