Yamaha service manual omission
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    I looked through the Yamaha XS1100 factory service manual and can't find the amount of gear lube that goes into the final drive.
    I suspect it's something like the middle drive, 4.4 oz. when filling after complete draining, 3.5 or 3.3 oz. when just changing, odd ?
    Nowhere can I find the number of ounces for the final drive, changing, complete filling when drained.
    Just interested.
    Can anyone answer please ?
    T.I.A. Done
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
  • BillyRok
    • Aug 2011
    • 421
    • Shortsville, NY.
    I have both an XJ and Xs manual. They agree that the final drive holds 0.32 US quarts but the middle drive amounts differ: 0.396 qts for the XJ and 0.38 qts for the XS although I'm not sure that's a measurable difference. I always go to the full line on the factory dipstick.
    Billy
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      Thank You Billy ! I have the Mechanics factory manual, I find the engine and middle gear oil amounts but not the final drive. If it's in there would you be willing to tell me what page in the XS manual ?
      I have the SH, H and LH with supplements.
      76 XS650 C ROADSTER
      80 XS 1100 SG
      • CaptonZap
        • Jun 2010
        • 1748
        • Denver
        Page 2-11 of the Genuine Yamaha XJ 1100J manual, it says;
        Final gear case: Approx. 0.30 L (0.26 Imp qt, 0.32 US qt)
        I fill it to the bottom of the filler hole threads and call it good.
        CZ
        • donebysunday
          • Oct 2012
          • 1737
          • New Berlin, Wi.
          CZ
          CZ, Thanks !
          That seems very full ?
          Maybe cut down on (what do they call it?) frothing, foaming, aerating ?
          Do you do the same with the middle gear unit ?
          Did Yamaha leave this measurement out of the XS1100 manual ?
          76 XS650 C ROADSTER
          80 XS 1100 SG
            CZ
            In Yamaha Manual 1st edition XS1100 same information on page 2-13
            Oil will blow out of the top if you overfill.
            Use the dip stick provided in tool kit......40 + years ago
            Dip stick was still available from Yamaha.....10 years ago.
            I like CZ fill to threads for final drive.
            Always remove filler cap before removing drain cap.
              Don't fill the middle drive up to the threads, there will be waaay too much in there.
              • MPittma100
                • Aug 2011
                • 2359
                Yamaha Manual
                Stick to the book.
                1981 XS1100H Venturer
                K&N Air Filter
                ACCT
                Custom Paint by Deitz
                Geezer Rectifier/Regulator
                Stebel Nautilus Horn
                EBC Front Rotors
                Limie Accent Moves On In 2015
                Mike
                • donebysunday
                  • Oct 2012
                  • 1737
                  • New Berlin, Wi.
                  Haynes/Clymers
                  Thank You All !
                  Maybe Haynes/Clymers had the amount listed for the final drive, I used to have all three.
                  Still the measuring tool will work.
                  76 XS650 C ROADSTER
                  80 XS 1100 SG
                  • CaptonZap
                    • Jun 2010
                    • 1748
                    • Denver
                    Quoting from the same source;
                    Middle gear case: Approx. 0.375 L
                    (0.33 Imp qt, 0.396US qt)
                    Recommended oil: SAE 80 API Hypoid gear oil.
                    SAE 80W90 may be used for all conditions
                    GL-4, GL-5, GL-6 ratings are all approved.
                    Yamaha doesn't always present information in the places we would expect.
                    It is probably in there, just not where you would first look.
                    CZ
                      I would HIGHLY recommend using 75-140w synthetic oils in both middle drive and final drive as opposed to the old school recommended oils. I found years ago that the 75-140w syn. reduced final drive temps. by 15 degrees after riding an interstate testing some 150miles@ a constant 80mph. Testing both choices for same distance,G.Junction, Colo. to Green River, Utah. Royal Purple was and is my syn. choice. Do NOT use same weight choice for synthetic! 80-90w synthetic oil does NOT have the same cling factor nor 'pound out' factor using equivalent conventional choices! If using 80-90w syn., it WILL cause an early demise of final drive bearings! Remember, heat IS equal to friction!
                      • Tom Andersen
                        • Aug 2003
                        • 75
                        • Pueblo, Colorado
                        make your own
                        https://www.xs11.com/xs11-info/tech-...-dipstick.html
                        1982 XJ650RJ Seca
                        2001 Yamaha XT225
                        2002 Suzuki DR650
                        2008 Suzuki DL650 VStrom
                        AMA charter life member
                        • donebysunday
                          • Oct 2012
                          • 1737
                          • New Berlin, Wi.
                          Dip stick
                          is no longer available though I just found one on ebay for 18 dollars.
                          I guess in the past I just added then checked with the dipstick, added/checked then again until I got it right, or as was said it's in the book somewhere ?
                          76 XS650 C ROADSTER
                          80 XS 1100 SG
                          • MarkD
                            • Jun 2013
                            • 488
                            • N. Michigan
                            Done, I did the same this fall, add the lube and check with the dipstick that was in my original tool kit. I made sure the bike was on the level and standing straight.
                            79 F
                            1967 Suzuki X6 Hustler
                            1973 Suzuki TM 125
                            1979 XS1100 F
                            2005 Kaw. Vulcan VN800
                            1991 BMW K75
                            • webbcraft2150
                              • Sep 2002
                              • 1605
                              • AUSTIN.TX
                              There was drawing posted here somewhere with dimensions. I made a couple out of scrap plastic.
