O rings in float bowl
  • alaskey2
    • Apr 2014
    • 271
    • 60940
    Finally had some time to take the bike out yesterday and it wouldn't start
    Sorted that out and turns out 1 and 3 aren't firing. Had spark, it's time to suck it up and clean the carbs.
    It's pretty easy to see what the problem is, there's an o ring in various stages of decomposition in the bottom of EVERY bowl. I got what I could apart, took a few pictures hoping someone could point me in the right direction on where this o-ring came from and where to buy a new one.
    This one was REALLY dirty
    If I had to guess, it came from here.
    A few of these bolts felt funny when they came out, I think there might be some tread stripping or corrosion. I marked the top EZ to remind myself not to crank them down.
    End of the night picture
    78 E
    • 7712
    Who was the last person to work on the carbs?
    It looks like they thought you had the later model carbs with "O" rings, and NOT the early WITHOUT. You should be able to just clean the carbs and re-assemble, set the float levels, bench sync, and install. You WILL need to do a proper sync and mixture setting once on.
    • alaskey2
      • Apr 2014
      • 271
      • 60940
      Thanks Phil!!
      The PO rebuilt them before I bought the bike. It always started so i never had a reason to open the carbs until now.
      78 E
        • 2037
        Alright Alan, fess up:
        Hope you have a sense of humor.
        • alaskey2
          • Apr 2014
          • 271
          • 60940
          That's too funny!!! Selective memory I guess
          78 E
          • mlew
            • Jun 2005
            • 226
            • Apex , NC
            You got the carbs down that far be sure to replace the throttle shaft seals .
            Slow down and enjoy life. If you are in that much of a hurry, you should have left eariler.
            Current rides:
            80 XS1100SG
            82 JX1100
            83 Venture Royale
            86 V-Max
            • alaskey2
              • Apr 2014
              • 271
              • 60940
              Is there a walkthrough or tech tip on the butterflies?
              78 E
                • 5058
                There are no threads around the fuel valve body. It is supposed to have a fiber-washer gasket if it is a 78 carb, not an o-ring. I suspect you have a transitional 78/80 carb bank.
                  • 5058
                  What I meant to say is “79/80” transitional carbs.
                  • alaskey2
                    • Apr 2014
                    • 271
                    • 60940
                    Hey Skids,
                    The Carbs have an E on the bottom, does that help identify anything?
                    And for everyone else, should I have plugs in the sides of the carbs without a fuel T? See picture below. Only one carb has a plug there,
                    78 E
                      • 5058
                      Hey Skids,
                      https://photos.app.goo.gl/ccaTV7Qxo7JHUCue8
                      Is the bottom port drilled all the way through??? If so, it is a fuel feed. The model E carbs had ports above the fuel feeds to accomadate breather tees that ran two hoses back to the air box. Did the pilot jets have screw-on caps?
                        • 8753
                        Those carbs are the early type, 78-79. Those plugs on the sides of the 1 and 4 carbs mean nothing, cosmetic only. Also, that O ring in your first pic doesn't belong to your type carbs, you don't need those.
                        • alaskey2
                          • Apr 2014
                          • 271
                          • 60940
                          I got the carbs back together, did a little bench sync. All four cylinders are firing, but the bike isn't returning to idle as quickly as I remember. Also, when I was trying to get a video of this, the throttle ran away (RPMs increasing on their own). Video below if anyone wants to chime in on that.
                          I also can't get the tab at the front of the seat pan to stay under the frame bracket, but that's probably just misalignment.
                          78 E
                            • 7817
                            The butterfly seals are a C. Not a standard o'ring. Many Mikuni carburetors use the same one. OEM is readily available. Mike's XS has them aftermarket. The BS38 & BS34 on the XS650 use the same seals.
                              • 7712
                              Until carbs are synced with gauges, you can't depend on the idle working.
