Xs1100sg
  • #31
    https://www.bikebandit.com/oem-parts...8405#sch226685
    #16 and #37 & 38, not sure what the difference is between them but I have all 4.
    79 SF parts bike.
    • #32
      Only need 1 #16 and all the screws, let me know and PM me.
      Thanks, Done };-)
      76 XS650 C ROADSTER
      80 XS650 G Special II
      https://ibb.co/album/icbGgF
      80 XS 1100 SG
      81 XS 1100LH/SH DARKHORSE
      https://tinyurl.com/k6nzvtw
      AKA; Don'e, UD, Unca Don'e
      • #33
        I've not heard from anyone, am I outa luck ?
        Thanks, Done };-)
        76 XS650 C ROADSTER
        80 XS 1100 SG
        • #34
          I have not made it to my storage unit yet. I'll let you know tomorrow and ask for a shipping address when I know I have the part. I usually send things USPS as it's across the street from me.
          • #35
            I don't have any screws but I have the nut. PM me you add. if you want me to sent it.
            79 SF parts bike.
            • #36
              i have a some of the parts, but only one of each bolt, short and long. Let me know via pm on what you need.
              • #37
                Pm
                PM has been sent to red bandit, Thanks !
                76 XS650 C ROADSTER
                80 XS 1100 SG
                • #38
                  I'll start putting this air box back together and see just what all exactly I don't have.
                  Thank You !
                  76 XS650 C ROADSTER
                  80 XS 1100 SG
                  • #39
                    It's alive
                    Originally posted by donebysunday View Post
                    Just bought, does not run, has fuel leak, owner wanted to fix but ran into the octi and gave up, noice bike if it'll run when I'm done !!!
                    https://ibb.co/album/d1kCbF
                    I rode this SG today that king queen seat sits me up so high I'm on the balls of my feet, I will make it a priority to find a stock seat and hopefully a 1980 !
                    The back brake is sticking (brought a rubber mallet with me).
                    The engine purrs at idle and starts with a tap of the button no problem, but occasionally coughs on slight acceleration (did not want to rev it up since it has not run in a long time) and while riding it started bucking and then run on less than 4 cylinders. When it's running right it has all the power I would/could want.
                    Scary, reminds me when I bought my 79 back in 79 the set up man says be careful it's very powerful. I pulled up to the end of the parking lot to get on the main street of town and it was rush hour W A I T >>> OK there's a spot to get in, came out of the drive onto main street sideways.
                    Now oil change, filter, full tank of non-ethanol, plugs, free up back brake, Oh I picked up an 850 reg/rect , 12.9v idle 1500 rpm 13.9v , 2500 rpm ,14.6v and the tach works great.
                    Thanks Guys !!!! Done, well for now, I'll keep reporting and make a video ASAP
                    76 XS650 C ROADSTER
                    80 XS 1100 SG
                    • #40
                      The engine purrs at idle and starts with a tap of the button no problem, but occasionally coughs on slight acceleration (did not want to rev it up since it has not run in a long time) and while riding it started bucking and then run on less than 4 cylinders. Then it would come and run great, guess I think I know it's the pickup wires, ahhh yeah prolly ?
                      I must get to work on this pickup wire possibility but I'm also painting the battery box and doing the other wheels for the 650, along with getting ready for the cold that's coming. No priorities, every thing all at once.
                      I think I'll get to those pickup wires ASAP.
                      76 XS650 C ROADSTER
                      80 XS 1100 SG
                      • #41
                        Xs 1100sg
                        Here's a pic of the air filter and the plugs that came out, wondering what the best gasket material would be to re-seal the filter ?
                        Those plugs are denso, never saw them used before, are they a good plug, where to get, what's the correct number ?
                        https://ibb.co/jLUYgV
                        76 XS650 C ROADSTER
                        80 XS 1100 SG
                        • #42
                          Replace the air filter. I used K&N in the '79's, but will be doing something different on my '78. The plugs I would use NGK, or find the cross-over match for the Denso. You may also look into a "modern" plug, iridium, as a replacement. Most of them are "resistor" plugs, so you can remove the resistor from the caps if you want for a little better spark.
                          • #43
                            Thanks Ray,
                            NGK is what I put in the engine now.
                            I just thought the filter was in such good shape it'd be a shame to toss it ?
                            I've heard good things about Hi-flo, anyone use one ?
                            T.I.A. Done
                            76 XS650 C ROADSTER
                            80 XS 1100 SG
                            • #44
                              Thanks Ray,
                              T.I.A. Done
                              No, haven't. The foam Uni-Flow sprayed with PJ-1 filter oil IS the best bet for a replacement air filter.
                              • #45
                                Is that UNI filter going to last, cleanable ?
                                It's the least expensive of all, compared to the K&N you can buy 2 and 1/2 of the UNIs
                                76 XS650 C ROADSTER
                                80 XS 1100 SG
