Voltage Drop at Idle
  • XSSIVEUS
    • Jul 2018
    • 91
    • Sheridan, OR USA
    Have a 78 1100E that runs great, maintains charge, fires right up, etc. Issue is that when I come to a stoplight and the turn signal is on, it slows down and then stops flashing. I have a fairing on this bike with a voltage gauge and it shows the voltage dropping at stop/idle.
    When riding the voltage is around 12-14 volts. At idle it drops to 8-10, less with turn signal. The gauge hasn't been calibrated in years, but comparatively it's probably a decent approximation. I replaced the flasher unit early this year during a restoration with a NOS unit.
    Is this a regulator issue, corroded contact issue, defective flasher unit, or something else?
    Thx
    78 XS1100E touring
    78 XS1100E stock
    80 XS1100LG Midnight Special
    83 XV920MK Midnight Special
    83 XJ750MK Midnight Special
    83 RX50 Special
    97 FLHR
    • 7808
    I have the same issue. My bike also runs rich and is low on power. The spark is weak.
    Your bike is 40 years old. The likely culprit is corrosion. Yamaha did not intend for you to keep a motorcycle for 40 years. Wire is made of copper. The Statue of Liberty is made of copper. She's green. Your wiring may be getting there, too.
    I may decide to build a new main wiring harness, since I have the tools and necessary skill to do it. Just no time right now. Every connector, pin, and wire color is available at http://XJ4Ever.com. http://www.sparckmoto.com is another source.
    A while back, I found corrosion removal options via Google. I have not yet tried it.
    How to Perfectly Clean Wires in Minutes!!!: Here is an old ham radio operators trick for cleaning wires for soldering that are old and corroded.  It is hard to find this technique printed anywhere! I am a ham, NH7ZE, and learned it from my elmer (mentor). I am passing it on.  I hope…
    Some time ago I found a YouTube about removing corrosion from the wiring of an old car. They disassembled the plugs and the same salt/vinegar process worked well on the pins.
    I don't recommend dielectric grease, but you'll find plenty of dissenting opinion on that.
    Best wishes!
      • 7808
      The first thing to do is remove the right side cover and the panel that the fuse box is mounted on. Behind it is the connector to the stator. Make sure that one is clean and conducting. Lose that one and it will take the stator with it. You'll know right away if it's bad. The plastic will be brown or melting.
        • 7693
        An easy first try is remove all the ground wires, clean them and the frame contact point, then re-assemble with some anti-seize smeared around the frame and connectors. Don't forget about the engine to frame ground, as it may be the big problem. This connects from the middle drive to the frame just behind the Left side cover.
          STOP/RUN switch internal contacts are a common issue creating a voltage drop. This switch COMPLETES the running circuit. I suggest unplugging it and remove it from bars, take apart and clean contacts by dropping switch assembly in a shot glass full of Evapo-Rust. Afer a couple hours, remove it, rinse with water and blow dry with compressed air. Re-assemble,plug back in together and re-mount on bars. After doing so, internal contacts of switch WILL look like new again as will the switch assembly itself.
          • XSSIVEUS
            • Jul 2018
            • 91
            • Sheridan, OR USA
            All good ideas. Will work through all until the gremlin is found. Thanks guys!
            78 XS1100E touring
            78 XS1100E stock
            83 RX50 Special
            97 FLHR
              • 5057
              Keep in mind also that break even for charging is something like 1800 rpms, Below that at you are running off the battery — which can discharge steadily with the brake light on, the headlight on etc... One of the most inportant grounds is the frame/volt regulator mount.
              • XSSIVEUS
                • Jul 2018
                • 91
                • Sheridan, OR USA
                Also a good idea. Thank you Sid!
                78 XS1100E touring
                78 XS1100E stock
                83 RX50 Special
                97 FLHR
                  • 2073
                  Reg/Rec
                  Along with all the above suggestions, cleaning and so forth, the absolute best mod for these bikes is from one of our members "Geezer"
                  This link takes you to his site :
                  He makes aftermarket Reg/Rec's for a host of MC's that will end the discharging of the battery at idle.
                  I'm going to assume that Your "E" is the one in the avatar, if so, I have a Pacifico fairing on my "G" also and a trunk with two brake lights and since I installed Geezer's Reg/Rec I no longer have to rev the engine to get the turns to flash at red lights
                  Also I have replaced the stock bulbs with LED's where possible.
                  HTH
                  • XSSIVEUS
                    • Jul 2018
                    • 91
                    • Sheridan, OR USA
                    Interesting idea. I'll read up on it. Thanks!:
                    78 XS1100E touring
                    78 XS1100E stock
                    83 RX50 Special
                    97 FLHR
                    • MPittma100
                      • Aug 2011
                      • 2359
                      Battery Ground
                      Do the bike and yourself a favor and improve the (poor) chassis grounds to direct battery grounds. You can achieve this by linking all of the chassis ground points with jumpers so as they all are directly connected to the battery ground terminal. A good chassis ground is a poor ground at best and causes the burned terminal pins due to high resistance.
                      The amperage output of these alternators is quite low. The electrics on the bike draw most of the amps away and the alternator just barely keeps up with the load. The Geezer upgrade helps. Replacing the incandescent bulbs with LEDS gives the alternator much needed breathing room.
                      1981 XS1100H Venturer
                      K&N Air Filter
                      ACCT
                      Custom Paint by Deitz
                      Geezer Rectifier/Regulator
                      Stebel Nautilus Horn
                      EBC Front Rotors
                      Limie Accent Moves On In 2015
                      Mike
                      • XSSIVEUS
                        • Jul 2018
                        • 91
                        • Sheridan, OR USA
                        Good advice Mike and will see how best to do so, thx.
                        78 XS1100E touring
                        78 XS1100E stock
                        83 RX50 Special
                        97 FLHR
                        • MPittma100
                          • Aug 2011
                          • 2359
                          Ground
                          Former ground conversation:
                          The engine idle speed when warmed up should be 1100 RPM. Anything lower tends to drain the battery more.
                          K&N Air Filter
                          ACCT
                          EBC Front Rotors
                          Mike
                            Hey there,
                            Just be aware that when trying to replace the TURN SIGNAL lights with LEDS, that you will most likely need to change to an electronic NO LOAD 2 PRONG flasher designed to handle LEDS. Messing with resistors and such defeats the purpose of using LEDS. The 2 prong flasher will go 1 of 2 ways into the plug, will work only 1 way. You will loose the SELF CANCEL feature though. There is/was a tech tip or post about a MOD to be able to keep self cancel feature with LEDS, you can search if so inclined, most folks don't bother using the self cancel anyways, just push the turn signal button straight in to turn off.
                            The stock Alt is rated at ~25 AMPS Max. The ignition system is fused for 10, but probably runs at 5-7, noboby's ever posted an exact figure for the TCI and the ignition coils. The headlight 55W=4.5amps, brake light 27 watts=2.25 amps, turn signals 27 watts x 2= 4.5 amps, gauge lights 8 watts x 4=2.5 amps, THEN you add additional running lights/trunk, and you can see how you can run out of available amps/watts with the charging system.
                            • donebysunday
                              • Oct 2012
                              • 1737
                              • New Berlin, Wi.
                              T.C.'s fuse block
                              No one mentioned the spade fuse block conversion from T.C., great upgrade.
                              Also going through each and every ground and power connection, cleaning, squeezing the female if not tight, cleaning the bulb sockets and the use of dielectric grease on all to help keep the connection from oxidation in the near future.
                              The battery itself, good, if lead acid, is it full of distilled electrically charged water ?
                              If you need to top it off to full wait to check at full charge, if you check right after filling it will read low.
                              Anti-sieze I never heard of before on the grounds ? Is it as good, better than dielectric grease ?
                              Check the amount of battery charge disconnected, 12-12.3v give or take a little and charge rate shown on the battery when running 1100-2000-2500-3000 rpm., by 3000 if you don't have 14v +- check connections again from the alternator, re-test. Still no ?, time for Andreas.
                              Please correct me if wrong !
                              Please excuse me if I missed the mentioning of these things previously !
                              76 XS650 C ROADSTER
                              80 XS650 G Special II
                              https://ibb.co/album/icbGgF
                              80 XS 1100 SG
                              81 XS 1100LH/SH DARKHORSE
                              https://tinyurl.com/k6nzvtw
                              AKA; Don'e, UD, Unca Don'e
